@SMSW @Larry Fine
I have a question for the electricians here, and anyone else who may be able to answer this.
I have a Widder heated suit. While it is very old, it is in like new condition, as it has very rarely been used. Included is a pair of heated gloves.
I remember reading that the Widder heated clothing is wired in series, but I don't know if this is fact. Widder is no longer in business, so information from them is no longer available.
When the entire suit is worn, the gloves plug in to the heated arm chaps, the chaps plug in to the heated vest, the vest plugs in to the power source. When using everything as intended, everything works properly.
Widder also sold a separate wiring harness to allow the gloves to be used separately without having to wear either the arm chaps or the vest. I don't have this wiring harness.
I thought that I would make my own wiring harness and set up the bike so that I could plug the heated gloves directly in to an accessory plug that I have on the plate between the handlebars. This would allow me to use these heated gloves without having to wear the vest.
I thought that this would be a simple two-wire harness to supply power like any other circuit until I read the warning about Widder being wired in series. I don't care about hooking them up and finding out that they don't work. That is only part of a learning curve. What I am concerned about is wiring them up incorrectly and damaging them. I obviously can not see inside of any part of this system to see how it is wired. Using the exposed connectors that are on the gloves, and on the arm chaps, and on the vest, and the power supply cord if required, my questions are;
1- how do I determine if these are wired in series or parallel?
I have test lights, multi-meters, 12V power supply, etc., available to accomplish basic testing.
Basic resistance tests tell me what resistance is in the circuit, and if there is continuity.
What I don't know is what test, and what test result, will allow me to distinguish a series circuit from a parallel circuit using what I have available to test with.
2- If they are wired in series and I connected them to a regular 12V parallel wiring set-up, what would happen? Will they be damaged?
3- Conversely, if they turn out to be a regular parallel set-up, and I connected them to a series wiring harness, will they be damaged?
Part of the reason why this is confusing me is that if this whole system is a series circuit as I have read, how does it work when one component is removed?
The vest plugs in to the power source, then the arm chaps plug in to the vest, then the gloves plug in to the arm chaps.
If this whole suit is wired in series, when the entire suit is being worn, the power would flow through the vest, through one arm chap, through one glove, through the other arm chap, through the second glove, and then back to the power source, or some combination of the above, but always in series.
4- Removing anyone of the components in a series circuit would open the series circuit and disable everything wouldn't it?
However, the entire suit can be used, or the just the vest and the arm chaps, or just the vest, and it all works fine even though components have been removed opening the circuit.
This seems more like how a parallel circuit works as opposed to a series circuit?
I realize that it there is the possibility that it could be wired as a series/parallel circuit, but I don't really understand that set-up and don't know how to test for that either.
I would appreciate any assistance that would keep me from ruining these gloves.
