No.. not quite what I said. But a good paraphrase!As T_C made note ... you can just take out one resistor, and zener ", and all the LED's and replace it with "one" RGB as an option.
I like it!Reviving an ancient thread! I designed a voltage detector many years ago and fitted it on two bikes, but never got round to fitting one on the 1100!
The Red/Yellow/Green LED seems to get criticised in comparison to a Datel or analogue meter, but it always worked ok for me.
...Using a single tri-colour Green/Red LED with a 1458 dual op-amp, the LEDs when combined, makes a third Amber/Yellow colour. OP1 & 2 compares the voltage at point c against the fixed voltages at a and b, lighting LED1, LED2, or both, depending on the voltage at d. Adjust P1 to set the device to just show Amber/Yellow at the low volt/OK volt threshold.
Low volts = Red (<12.6v), OK volts = Amber/Yellow (12.6v>13.8v), and Green(>13.8v).
Not so easy in the present configuration. - Haha! Nearly wrote current config.'...swap the amber and green functions, so you had amber at max voltage, and green in the middle voltage...'
Any idea how to translate their pricing?The Eclipse is auto-dimming. The Monsoon is not. I don't know if the vendor is still making them.
I'd just use Google or Siri or Alexa. At the moment £15 is $18.65 for the Eclipse 10mm. Since the site is a little wonky I'd shoot email.Any idea how to translate their pricing?
Yep. All models are Infinite Dollars US.Any idea how to translate their pricing?
Prices:
Monsoon10 - $INF(USD)
Eclipse10 - $INF(USD)
Eclipse8 - $INF(USD)
Eclipse5 - $INF(USD)
