JPKalishek
Armadillo Kicker
Yeah, I had to read through to make sure what size tire you had when you said "By The Book" and I see Michi tires that don't come in the size needed. I used the 150/70 PR3 when I ran them. Taller by a bit than the 170/60, and the Two Tone STeed doesn't fit the 170 tire as well as the Black does (it has a 170/60 on its way) Also, the stands wear and when they do, it hangs lower because of the spring. The Black's got so worn that dropping off the center stand would remove the spring! I'd drop the bike to leave and the sidestand would drop and kill the engine. I had to braze the frame bracket and stand with silver brazing rod some (t'was before I had any welders), grind things to fit, grease things like they should have been (I think I was the first person ever to lube the thing when I bought it) and it has been fine. So get closer to the right size tire and check the stand and frame tab for wear, you should be back to normal.
