Cruising along at about 80mph during my morning commute my ST1100 started losing power. I rode about 1 more mile before I pulled over and the bike ran very rough (1 or 2 cylinders) and died. It felt like it was starving for fuel. The tank was about ? to 1/3 full and I had been on the road for about 40 miles. Temperature should not have been a factor since it was about 28 deg F when I stopped (thanks for Gerbing electric clothes!). I opened the fuel cap and did not hear a rush of air but it?s pretty noisy on the side of the freeway. The bike started again after a few minutes, ran a little rough (the choke smoothed it out) and then ran normally. I decided to go back home and at about 40 miles it starting starving again and finally died.
I got home and ran lots of tests. Fuel pump is putting out about 1-1 ? PSI and 1800cc per minute. Ran the pump for ? hour unloaded (with very good flow) and ? hour more into a pressure gauge (1 ? PSI). So the pump seems OK. I just rebuilt the Fuel cutoff about 5,000 miles ago. Still, I tested it by applying suction and it opens at 1 to 2 inches of vacuum. Also checked the fuel cap vent line which is open and vented near the kickstand.
The vent action on the fuel cap seemed ?sticky? so I opened, cleaned, and re-assembled it as shown on the other LiST.
By the way, the bike is coming up on 124,000 miles now and this is my first failure.
I?m thinking that the fuel cap was not venting correctly. But I?m a little bit afraid of the bike now. Some of my commute involves a toll road with no shoulder to pull off, I got lucky this morning.
I?m thinking of replacing the pump, cap and bypassing the fuel valve just to feel better but that?s LOTS of ca$h.
What do you folks think?
Rick
Rick
