I think those cracks happened the first attempt trying to install alternator with lewis-pin method which i failed.I believe they cracked when i keep torquing without the gears properly aligned. Because they weren't there the at the first inspection. They are on one side and tiny cracks but still it is a risk and i have to take at this point. Prices gone really high because of the exchange rate.
And another mistake i made was with the clutch. Last night i found out that i put the guide that rod goes in to behind the plate to the axle instead in to the release plate. Fixed that and it is working now. The plate scares me more than the alternator. I am not that good with aluminum welding.Used to barrow friend's machine and work on less risky parts but this i could not risk it so i took it to a shop. It looks ugly, feels strong but i will never be sure. Will try to find second hand release plate.Also will it cause vibration this way? i don't know.
Apart from that i had the chance to ride the bike for a few minutes last night for the first time and it felt really good One thing i noticed is that there is a knocking? feel at the handle bar not sure where it is coming from.It is not from turning left to right.It feels it is doing it in forward-backward direction like between accelerating and braking. Also the front brakes are compressing the disk a little so that might be it. I can't hear where it is coming from because of the very loud exhaust.
The pipe is so rusted,have to cut it from before the 'Y' shape where the first 2 pipes joins in to one and then those two joins together. Searching for a ready made 'Y' that will make my job easier. Or maybe i will not join them at all. Left side cylinders to one muffler and right side to another. Any ideas?
