St1100 valve seals
portugal
ST1100 SC26
Dont k
Hi, I need to change valve seals on my st1100L, because is consuming oil. Can you explain me how to do that? Thanks
Lake Montezuma AZ
2003 ST1300A
What is the mileage? I would do a compression test first to check piston rings and valve sealing. Not an easy job to change valve seals, you must remove the springs which means removing the whole head...unless you find a way to compress them from the top.
  • Like
Reactions: jrp
fpatrick007
portugal
ST1100 SC26
Dont k
1
About 92000 miles. First I will do a compression test as you say. Thanks
fpatrick007
portugal
ST1100 SC26
Dont k
wjbertrand
Ventura Highway
Ventura, CA
When I changed the valve guide seals on my ‘93, there was no change in oil consumption. That bike tended to burn between 1/2-1 qt between 3000 mile oil changes. The problem must have been due to oil control rings as compression was in spec.
