shands
Stuart
Hiya guys,
Just wanted to see if anyone has seen behaviour like this before before I go stripping everything down and disturbing gaskets/draining fluids/etc unnecessarily.
2005 ST1300 with 72k on the clock. Occasionally, when slowing down to a stop (clutch in, and down through the gears to 1st) - there's a horrible (and I mean embarrassingly so) grinding noise (almost like there was no pad left on the brakes. Discount that one though - as they were replaced a couple of weeks ago). The pitch drops with the speed (depending on the gear)
In third gear at 30mph with the clutch in - you can hear a slight rumble/chatter, but noticeable. 2nd gear at 15/20mph - it's very noticeable. In 1st gear <10mph - it is loud!!
Pulling off, with the clutch biting - it's no where near as bad (only a slight murmur). With the clutch released entirely - nothing. At speed - also nothing.
When it happens (as I say, it doesn't happen all the time) rev'ing the engine with the clutch pulled in, the noise 'pitch' doesn't change - which makes me think that it's not engine related.
Looking at the diagrams, namely this one here, my money's on part #23 - the bearing under the pressure plate. Has anyone had/heard of anything like this at all?
Thanks in advance!
Thanks in advance!
