- Joined
- May 6, 2008
- Messages
- 6,183
- Age
- 66
- Location
- Lompoc, California
- Bike
- 07 & 12 ST1300A
- SPOT
- LINK
- STOC #
- 8057
That's unusual, we are more likely to see them only flat on the bottom.Looks like they are only bad towards the top,,,,, lol,,, CAt'
What lead you to check them.I'm not sure if these bearings are worn out or not? They only have 165,000 miles on them since last replacement at just over 100,000 miles.
My sentiments exactly... those rigs must wiggle like a lamb's tail...I can’t even imagine how folks ride on those without knowing the bearings are toast.
I was changing the tire and found this. There was no noise that I could tell or no wobble yet. I check the bearing for smoothness every time the wheels are removed.What lead you to check them.
Where they noisy?
Front wheel wobble?
Tire change time?
There was no noticeable movement in the wheel prior to removing it. All wheel bearings are checked every time I remove the wheels.My sentiments exactly... those rigs must wiggle like a lamb's tail...
My GF's NT700VA had a worn front wheel bearing (barely clicking when trying to wiggle the unladen wheel), scared the crap outta me right in the first turn... "DANG! IT MOVED!!"
Turned out the old ones were pattern parts + the PO was a fan of pressure washers... bad combo...
I check them bearings on every occasion the wheels come off, they're out if only the slightest resistance or roughness can be felt...
That's likely a more frequent inspection than some do.There was no noticeable movement in the wheel prior to removing it. All wheel bearings are checked every time I remove the wheels.
I think that may be an equal and opposite reaction to the flatness at the bottom of the tire.That's unusual, we are more likely to see them only flat on the bottom.
