Shuey
- Joined
- Jul 3, 2007
- Messages
- 2,100
- Location
- Niceville, FL
- Bike
- FJR1300 ES, 2018
- SPOT
- LINK
- STOC #
- 7005
On replacing OEM ST1300 headlight bulbs with brighter, whiter LED ones . . .
Ok, I've spent the past 2 hours or so reading threads regarding LED replacement headlight bulbs. I'm . . . confused.
My dated experience was with replacement bulbs that, other than bending/breaking off two tabs, were a simple replacement - no ballast, no fans, just replace and roll.
Most of the current info I read seems to recommend bulbs with fat fan ends that may or may not require modifying the rubber boot to fit.
So, I'm looking for bright white, plug and play, and as bright as I can get that the bike will support.
Maybe time for an update thread on what's current?
Suggestions?
What about AUXITO H4/HB2/9003 LED Headlight Bulb with Fan, 100W 20000LM 6000K White, 2022 Upgraded? The fan seems small and doesn't look like it interferes with the rubber boot. https://www.auxito.com/collections/9003-led-bulb/products/9003-led-bulb-h4-hb2-led-headlight-bulb-20000-lumen
Sylvania 9003 LEDs look good and have the advantage of being readily available at most auto supply stores. Comments?
Thanks,
Shuey
Suggestions?
Thanks,
Shuey
