I have read on some of the forum posts that the factory wiring colors appear to be somewhat a "suggestion" in places, so I'd triple check them before proceeding with any wire loom surgery.
Josh
Josh
I’ll take that into account. ThanksI have read on some of the forum posts that the factory wiring colors appear to be somewhat a "suggestion" in places, so I'd triple check them before proceeding with any wire loom surgery.
Josh
Maybe with aftermarket equipped police equipment but not with the factory supplied loom. Honda to a fault has tight QC and there is no variation.I’ll take that into account. Thanks
So I guess it’s not the batterystarter spins lovely without any issues
Igofar the battery is fine; my issue is the clock re-setting itself - I don't even need to start the bike, if I turn the key on and then off, that's sufficient for it to reset.Yes, he said it spins lovely, but does that mean enough?
He needs to check the battery with a volt meter when he attempts to start it and see how much it drops.
Which is why I suggested that he checked the readings of just the battery, then with the key on, then what happens when he turns the key on.That's three battery verification suggestions s from Larry in this thread.
I'm not nearly as knowledgeable, wise, or experienced in troubleshooting these bikes as are others around here, but this much I DO know:
Testing battery voltage with a meter does NOT assure us of a healthy battery.
It really needs to be load-tested, at least.
My issue with clock & trip meter resetting ended up being the 12 V keep-alive not making it to the instrument cluster. Without the keep-alive 12V the clock & trip meter lose their memory when you turn off the key. Message me if you need the particulars.Any update on this matter as my 2002 just developed the same fault - the battery is fairly new, 6 months, starter spins lovely without any issues and all fuses on the lhs of the bike are all good. Any help would be appreciated!!
Good find! Glad you got it sorted out.Yeah, it was aimed at folks that have a background that would allow them to "dive right in." I figured my audience is: 1, Motorcyclists, and 2, ST owners, who either have the background, or have the $$. And yes, I found a broken wire; emphasis on "found," as opposed to "broken wire."
I sincerely hope it helps someone; This forum definitely helped me to find this problem.
