- Joined
- Apr 22, 2011
- Messages
- 1,151
- Age
- 68
- Location
- Camarillo, Ca
- Bike
- 2006 ST1300A
- 2024 Miles
- 002552
I am using an external sensor that screws on to the end of a METAL valve stem. (SPY tpms)
On my daily commute my front tire increases by 3 psi and my rear tire increases by 4 psi. The only reason the tire pressure rises is because of internal tire heat. Using 1 psi change = 10 F change. Then 4 psi increase would equate to a temperature rise of +40 F (+22 C) and 3 psi would be a temperature rise of + 30 F (+17 C).
Now the front sensor temperature only reads an increase of +2 C and the rear sensor reads an increase of +12 C which is does not correlate to the pressure changes. The front sensor is out in open fast moving air so it is quickly cooled. The rear sensor is in "blocked" air flow by the saddle bags and is getting some engine heat as well as both side catalytic heat and muffler heat. There is still enough air flow that it still reads 10 C below what it should. So the temperature reading is NOT very useful with external sensors. Do NOT set limits based on temperature. I have no data on the internal type sensor.
The pressure increase is only what you should watch. Make a mental note of your starting pressures then see how high it gets near the end of your trip or where you are going fast at the hottest time of the day. This will give you a working range based on your set up. There should be less change on cold days and more change on very hot days.
Now my set up is different than yours since I am running double dark. I have set my cold rear CT to 26 psi and my front to 35 psi in order to get a smoother ride. This is a worse case set up since lower pressure will cause more stress in the tires but I am only seeing about 4 psi increase in the normal outside temperatures of 20 C to 30 C. I just missed getting data when it was 48 C last month and it will be a few months before I will get data at 0 C... I am guessing that at 0 C there would be a 2-3 psi increase and at 48 C there would be a 6-9 psi increase.
So if you get a TPMS Just keep track of your pressure operating range.
