st11ray
I have a Whelen run/brake/turn strip light mounted to the bottom of my Givi plate and Hyperlites mounted to the side reflector mounts.
Skene, Denali and Clearwater are all well known names and shouldn't give you any issues. You pay a premium for these though!I found these lights that might work. They even have a decelerometer for engine braking without applying the brakes, they will light up. Has anyone tried these?
P3 Lights with Decelerometer & Turn SignalsSkene Lights Online Store
Online ordering for all Skene Lights visibility lighting products including the P3, Photon Blaster, IQ-275 dimmers, LED modules and more.www.skenelights.com
I did notice though, it appears that they are single color, where the ADMORE LIGHT BAR PRO has dual colors, also has the decelerometer and a BT app. Which is interesting, but maybe more than I want. If the Skene lights were both amber and red, like the Admore, I would go for those. Not much difference in price, but the Skene has two smaller light units as Admore's one.
I also found Denali, but all their stuff seems to be out of stock on their website.
T3 Modular Switchback Signal Pods - Rear
The T3 is a unique and innovative approach to the common turn signal blending white visibility lighting, red brake lighting, and amber turn signal lighting into one modular system. The front T3 turn signal pods feature super bright white running lights that switch to amber when your turn signal...denalielectronics.com
This looks pretty cool too!
Gen 1 - Lightning Strike - Get Lightning Strike
Gen 1 Lightning Strike is the 1st patented vehicle visibility system for motorcycle safety. High-intensity, optical LEDs can alert drivers to your location.getlightningstrike.com
If you really want to spend a dollar, check these out.
Clearwater Lights LED Motorcycle Lights and Off-road Vehicle
At Clearwater Lights, your safety is our primary concern. Clearwater Lights are the only fully-adjustable high-powered LED auxiliary motorcycle and off-road lights available, allowing you to maximize your ability to see and be seen in constantly changing ambient light conditions.www.clearwaterlights.com
I have, as well as the ones built into the back of jackets / vests. Some have turn signals built in as well. Not sure I like them either.Have you seen the helmets with the brake light on the back of them ?
I agree about the "cry wolf" factor but what I have been reading is that the sensitivity is adjustable. I sometimes decelerate entirely using the engine or downshifting, until I am almost stopped, then apply the brake, which is why I am considering this. In this case no brake light would come on until almost stopped. Which would be more dangerous. So if they can be set to go off when slowing down significantly faster than just coasting, I think it would be safer. Plus considering the "cry wolf" factor, it is not likely you would be "false alarming" the same person more than once to cause people to ignore the light. Unless that same person is following for miles and miles and you repeatedly make it appear to be a false brake. At least that is my logic on the idea.I don't know if I like the decelerometer feature.
Yes it can give you a few fractions of a second up to perhaps a second faster activation time, and needs no touching of a brake lever / pedal, but it will also give false brake notificaitons to whoever is behind you when you let off the gas. (depending on how sensitive it is.) You might scare them a few times or make them think you are braking, but it also might become a "boy who called wolf" scenario and they think your brake light is just "glitchy." Think of how you'd react if you saw someone in a car ahead of you with brake lights activating like that.
I'm all from more lighting, something that makes the triangle of light in front and rear, and something that flashes the brakes to get a drivers attention - but this isn't a feature I'd want to install on my bike.
I would hate to be riding behind someone with one of those on twisty roads. I would have to make a pass to keep from seeing them braking constantly.I agree about the "cry wolf" factor but what I have been reading is that the sensitivity is adjustable. I sometimes decelerate entirely using the engine or downshifting, until I am almost stopped, then apply the brake, which is why I am considering this. In this case no brake light would come on until almost stopped. Which would be more dangerous. So if they can be set to go off when slowing down significantly faster than just coasting, I think it would be safer. Plus considering the "cry wolf" factor, it is not likely you would be "false alarming" the same person more than once to cause people to ignore the light. Unless that same person is following for miles and miles and you repeatedly make it appear to be a false brake. At least that is my logic on the idea.
In my opinion this is something that would drive me and most other drivers on the road crazy if they became popular and everybody's brake lights were flashing on and off all the time. I think it would create a more dangerous situation as everyone would learn to ignore the flashing brake lights. In my opinion it is better, in any situation where you are decelerating significantly enough that this system would be of benefit, to train yourself to get in to the good habit of applying just enough brake lever or brake pedal to activate your brake light. This will give drivers behind you warning that you are slowing considerably. This will provide you with the same safety benefit. Once it has become memory muscle, it will always work even if this electronic system fails or if you are riding a different motorcycle that is not equipped with this system. Best of all it costs you nothing, which allows you to keep the money that you need to spend on this system for gas and tires.I sometimes decelerate entirely using the engine or downshifting, until I am almost stopped, then apply the brake, which is why I am considering this. In this case no brake light would come on until almost stopped.
Not sure but I think in most jurisdictions, as long as you are not strobing blue, and possibly red, you are OK. Otherwise they would have to arrest the wreckers!Not sure true strobing lights are legal unless you are a LEO ? ...
