I did not know that but in the ownersmanual page 100 idle speed they do not write that to pull the black knob back.After you adjusted your idle (with a JIS driver) did you remember to pull the black knob back outward to lock it in place?
I think my wax sensor is dead because when i start cold the engine iddle goes to low and the engine shut off.All it does is take the bind off the cable/spring at the end of it and keep it from wandering around.
The knob is simply to identify the adjuster, use a JIS screwdriver, because if you try and turn the know, you can twist it off and break the end off the cable.
I am also trying to troubleshot some issues when starting my ST.Thanks for all the replies guys, had idling issues for a long time which improved a bit after I replaced the throttle body assembly with a used item. Better, but still not right. As the issue is with the speed of idling after starting (hot or cold), I'm guessing the used wax assembly might have seen better days.
Thank you, it makes sense and it is exactly the explanation I was looking for.I often find its not the idle wax valve itself that fails, but the little threaded rod that goes through the small black plastic barrel gets fouled.
Do NOT try to adjust the nut (per service manual) although some folks will jump in and say they have done it, most of them find out later they just caused other issues in different areas.
Anyway, what I've been finding is the threads catch on the sharp edge of the hole on this piece, and sometimes it sticks, sometimes it raises the RPM up and runs away, other times it may prevent the bikes choke to work, so the bike stalls and dies.
The fix is really simple, clean all the crap off the barrel, and make sure everything is moving smoothly, and not covered with crap, as most of them are.
Nope, just remove the air box assembly and your looking straight at it….sort of.Thank you, it makes sense and is exactly the explanation I was looking for.
I guess its means removing the throttle assembly to get access to it. Trying to spray WD40 through the hole will probably not work considering that the junk is behind the rubber cap or even damage the wax inside?
You should definatly tell themSo it really does use ...WAX?
That sounds crazy to me! All the high-tech (for its day) braking and stuff - and the throttle operates based on melting wax?
That is simply hysterical.
And I'm laughing.
And I'm not telling any of my riding buddies.
Yep, my wall of shame display section.
My Honda lawnmower has one.So it really does use ...WAX?
And I'm laughing.
And I'm laughing.
