Indicator (turn signal) reminder. audible warning
Lincolnshire, UK
Hello everyone,
I have made a modification to my Pan, something which stemmed from a mod I did to my previous bike. For those of us who can often forget to cancel the indicators at times and to the rest of the world following behind wondering just what the hell are you doing, making yourself look like a complete novice....enough said!
I obtained from the online auction site we all love to browse on, a pair of 12v warning buzzers. Not at all expensive for what they achieve and the safety aspect of this is so evident. They can still be heard at 70 mph and whats more important is the fact that they grab attention around the town especially when there are loads of pedestrians around that quite often don't look before stepping across the road.
The buzzers are installed to each indicator wiring loom, either by the quick clip type of connector that clamps onto existing wiring or like I chose to do, baring each wire of the buzzer and feeding it into the orange connector of the indicator loom and clipping the connector back together. The friction of the tiny metal plates will hold the wire in place with no need to solder.
Each buzzer can be placed onto the back of the black mirror mount by either sticky pads or with hot glue and all is concealed by the mirror housing. With all this in place the sound is not obscured heavily and as stated before the buzzers can be heard when travelling at speed reminding you that the indicators are on.
You do get used to the sound after a short while and ever since I did mine I feel a lot more comfortable around town as when I am showing intentions to turn, people do look to see where the noise is coming from.
Attached are close ups of the buzzer and also a video of the indicators and sound in action.
Thanks for reading, safe riding.
:wht13:
thanks for that, def on the list of things to do over christmas
This is what I have fitted,works great,though I now have it disconnected after using it for 8 months,it has me trained to switch the indicator off quicker,cheap too,
ebay item number 320477262702
Hi All. You can get these sounders over the counter at Maplin Electronics retail shops in any of their UK outlets;best ?3 I ever spent! Ed.
Hello everyone,
:wht13:
Thanks for posting. I have to be one of the worlds' worst for not turning mine off. I wonder if you could get a warning with a built in time delay before it comes on? So if I turned them off after , say 10 or 15 seconds, the buzzer would never come on?
Looks like Radio Shack has some buzzers and chimes that will work. I will have to check them out. I'm thinking of something like a door chime module like you have in a car? :think1:
Jay
Just make sure whatever you get, does NOT sound like a backup beep from a big truck... I can see, at a stop light where you are turning, someone in front of you thinking the truck in front of them is backing up..... and causing them to back up into you to avoid it...
My thoughts exactly. And if you happened to be sitting at a long red light and didn't want to keep hearing the beeping, you could simply turn the signal off and then back on again.
Nice. Wish they were sold in the US.
I will attempt to get this fitted and let you all know how it performs, maybe the seller would sell/send a batch to the US in a group buy thing but I suppose that needs someone to organise in US or maybe this end, I may email the seller to see if it would be possible.
It would be greatly appreciated if you could find out more info. I'm very interested in this buzzer.
Mr. Boring AGAIN!You may know by now that I am a big fan of audible indicator warnings.I have been "well round the block" in trying many types ,pitches & sound delivery levels of a range of sounders,beepers etc. & the bottom line is ,if YOU a'int hearing it, it's pointless!And now(Yawn) ,I use the Maplin Electronics 12v 105 dB sounder which even at my biblically advanced age can be heard easily up to 50mph (I am not partial to signalled manoeuvres above that speed given the usual abilities of those around me) Ed. P.S. The standard "last trench warning" an airline pilot gets that he is too low is an audible recording not a visual one).
If you wire the ground wire from the buzzer to the brake wiring it will cancel the buzzer evrytime you apply the brake,handy when you are sitting at a junction
Hi Broc11,good tip! As an "OldCodger" I have always found it to be an extremely sound approach to give those around you every possible opportunity to observe & hopefully understand what it is you will be doing next! I always leave indicators on when stationary at a junction I am intending to take as a result of this thinking. Ed.
