Oil Leak --- Advice Needed ASAP!
I am going to have to disagree with it being an oil leak from the water pump...it appears to simply be coolant leaks from loose clamps that caused it road grime to mix with it and look like an oil leak...very common. The oil seepage around the valve covers is normal. As far as cleaning goes...use two inch wide paintbrush and gentle decreased like simple green or pinesol and as pointed out keep it away from electrical stuff. .02
michaelbrooks
Greer SC
2003 ST1300 ABS
I am going to have to disagree with it being an oil leak from the water pump...it appears to simply be coolant leaks from loose clamps that caused it road grime to mix with it and look like an oil leak...very common. The oil seepage around the valve covers is normal. As far as cleaning goes...use two inch wide paintbrush and gentle decreased like simple green or pineapple and as pointed out keep it away from electrical stuff. .02
2" paintbrush??? I don't know about being that gentle with cleaning the motor. I don't see that doing a whole lot.
010688
I think you are going to find it will clean up very easily. I'm in the camp it's a mixture of dried coolant and road grime. It looks worse than it is. If you need something a little more aggressive try wetting a rag with brake cleaner and wiping the engine clean. I wouldn't spray brake cleaner indiscriminately though. I had a similar experience at 65,000 miles. I freaked thinking "oil leak" or water pump seal. I ended up cleaning everything well then snugging the coolant hoses then watchful waiting. I just passed 130,000 miles without a recurrence.
OhioDeere
Been There, Done That, Got the Shirt.
Lima, Ohio
06 ST1300
Exactly... clean it up, study the situation while engine runs... take gas tank off and top air box, give it a good inspection of all hoses and make adjustments or replacements as needed.
while there since you don't know exactly the previous maintenance, put new valve cover gaskets on it.
I would probably just drain all the coolant out of it and change all the hoses and new hose clamps on it anyway while your into that deep.
then enjoy another 50,000 miles of riding.
michaelbrooks
Greer SC
2003 ST1300 ABS
Thanks Doug, I appreciate the advice. I'm going through the cooling system now and checking everything. Going to clean things up and go from there.
