- Joined
- May 6, 2008
- Messages
- 6,187
- Age
- 66
- Location
- Lompoc, California
- Bike
- 07 & 12 ST1300A
- SPOT
- LINK
- STOC #
- 8057
I ate up a T30 rear tire faster then any other tire I have ever used on my ST1300.That would be a Bummer!
The T30 front (single compound) is great and the T30 rear (dual compound) has decent wear in the center but the sides are much too soft. The T30s allow me to push the ST to a respectable speed and that is their downfall. Bridgestone just needs to fix the too-soft side tread on the T30 GTs and they would have the premium ST tire. I am installing a PR-4 on the rear this morning and I will be testing it during Tmac this year BR.I ate up a T30 rear tire faster then any other tire I have ever used on my ST1300.
Didn't you just replace the flange bearings? You don't think that had an effect? If I was burning tires like you (used to, BTW) I'd be putting Shinkos on......just sayin'........have fun.........ffBTW the strange wiggle in the rear went away with the new tire.
Great question!Didn't you just replace the flange bearings? You don't think that had an effect?
On an old Goldwing I used to have the bearing play in the rear wheel made it feel like I was herding sheep....made it scary enough that I didn't corner like I usually would....hence the question....if it didn't scare the crap out of you maybe it did have an effect on the tire wear.....have fun......ffGreat question!
I'm not sure it that bearing issue would allow any extra movement or just drag?
Quick reply to this message Reply Reply With Quote Reply With Quote Multi-Quote This Message ...to the topTop
Thanks, I didn't think it would, but didn't give it much thought.FYI, driven flange bearings do not effect on the trueness of the wheel's rotation--at most they provide a very slight amount of power loss as they fail. Further, their failing does not create any lateral slop of the wheel on the axle--the inner races of the flange bearings are on a collar which is compressed by the axle.
The wheel itself is directly supported by other bearings on the axle. The flange bearings could be left out and the rear wheel would run true and would have no lateral slop (but the driven flange and splines would wear out very quickly).
Should be interesting to see how the Wing front works for you!had 023's got about 7-8000 just installed a 130/70 zr18 exedra max tire on front replacing 110/80zr18. It is for a Goldwing, fits and looks good by next year I'll give a mileage update
Bailey If you truly ate up a GT023 that bad in 900 mi. There is something really bad going on with your bike. If its a bearing issue I can't imagine that you wouldn't have felt it in the bike if they were that bad..On the other hand if you really do ride that aggressively I hope your life insurance is paid up. It's only a matter of when not if.....I wish you well ...BillThanks Bill!
I know I have to Pay to Play, but holy moly. I decided to not push another ride on the 023GT and pulled it off with less then 900(nine hundred) miles on it as the left side was about wiped clean.
But when I pulled the wheel off last I found the Driven Bearings to be toast so I'm headed off to pick up a pair of 6905-2RS HCH(6905RS Koyo) before I can try the T30 GT this weekend.
Bailey's street skills are above reproach and he is always in control even if he seems fast to most mortals. You may want to think twice about lending him your track bike though.Bailey If you truly ate up a GT023 that bad in 900 mi. There is something really bad going on with your bike. If its a bearing issue I can't imagine that you wouldn't have felt it in the bike if they were that bad..On the other hand if you really do ride that aggressively I hope your life insurance is paid up. It's only a matter of when not if.....I wish you well ...Bill
Same here Mike. The T30's are very short lived. The best were & still are the oem's 020 BS. On the st1300 the T30 has just over 6,000 miles at wear bars.I ate up a T30 rear tire faster then any other tire I have ever used on my ST1300.
Thanks Kimball! :bow1:Bailey's street skills are above reproach and he is always in control even if he seems fast to most mortals. You may want to think twice about lending him your track bike though.
No 'chicken stripes ' on those tires!......more miles on the sides than center. I definitely see that mileage is irrelavent in your case....pay to play. I occassionaly 'play', but even at that, expect to get in the 10K range out of rear 23(non GT). With 2,500mi. on them, and 'played' way hard on them the other day in the mountain twisties south of me, still showing center mark from mold!OK, I was off a little. Turns out i actually have 1100 miles on this BT023gt rear, I didn't think it was worth the risk of getting in another several hundred mile ride in on the tire safely. So I popped on a new BT T-30 GT rear to match the front, but found the Driven bearing toast. So after replacing the bearings i'm ready to test the new rear.
I didn't question his skills....Dale Earnhart's skills were above reproach as well...Just don't want to see someone leave us early unecessarily...I know I know when its your time its your time...Mebbe....I think we can sometimes hurry things along because of our free will...BillBailey's street skills are above reproach and he is always in control even if he seems fast to most mortals. You may want to think twice about lending him your track bike though.
......originally applied to pilots.......never previously thought of applying that to 'up on two wheels'........but DEFINITELY very true, 100%!A line we used to give new riders at the school - "there are old motorcyclists and there are bold motorcyclists, but there are no old, bold motorcyclists". Apparently, Bailey has defied the odds on this for more years than most! Continued good luck to him.
I find your comments rather rude and negative Bush.A line we used to give new riders at the school - "there are old motorcyclists and there are bold motorcyclists, but there are no old, bold motorcyclists". Apparently, Bailey has defied the odds on this for more years than most! Continued good luck to him.
