Rear shock recommendation
Afan
... and this is my real name.
Urbandale, IA
1998 ST1100
8832
After some research - I still didn't figure out if it's better to stick with OEM or look for an aftermarket shock. Works or Progressive?
I'm not an agressive or pushy rider, so any "sporty" solution is not necessary.
The model number is 52400-MAJ-G41 (96A-02A), right?
Hereford, AZ
2020 Moto guzzi V85T
Re: Rear shock recomandation
I personally would not get a stock shock. I would go with an after market. You really have two choices and it come down to the spring. Do you want a progressive wound spring or a linear rated wound spring. I think if it were me since I have had a progressive and I have not had issues with it I might leans toward that but if you are pulling a trailer I would look at a linear rated spring. Also make sure that it is re-buildable.
The progressive shock I used is the Progressive 465
Rochester Mn
2014 FJR ES 2009 WEE
I'd take what Uncle Phil and John O recommend very seriously....on an 1100....and get the right spring for your weight...good luck....ff
Rura Penthe, Arkansas
2933
Progressive has given me much better service & performance than either of my Works Pro Racers or the OEM's. After 50K I sent it in for a rebuild and IIRC the total rebuild cost including return shipping was about $10. I have over 100K on the shock. Couldn't be happier.
West Michigan
'98 ST1100
8470
+1 That's what I'm using and I'm happy with it. You can find one at much less than list price on Amazon or one of the well known MC parts warehouses.
West Michigan
'98 ST1100
8470
Nice to know !! Thanks.
Afan
Afan
Urbandale, IA
1998 ST1100
8832
I run Works Pro Racers on all three of my ST1100s and have been very pleased with them.
Does "Racer" part means $100 more then just "Works Pro"?
:D
Afan
Afan
Urbandale, IA
1998 ST1100
8832
Thanks guys, I really appreciate your help. I'm shopping now... I'll check for both brands and most likely the price will decide the finalist. :)
P.S. Don't see if the Works Pro can be rebuilt too? I'm assuming it can.
Donegal, Ireland.
Vstrom 650
I fitted a Wilbers, very pleased with the difference, then again it was bound to be a big difference because the oem shock was horsed.
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
OEMs have worked just fine for me over 178K, Afan. I'm not a Ricky Racer but am quite comfortable riding spiritedly with Honda's shock. The price is reasonable, considering... And yes, that's a good part number.
FWIW YMMV
via iPhone 6
British Columbia
2021 RE Meteor 350
+1 for OEM. IIRC, I was considering a Progressive 465 a few years back, until I found the adjuster ring is at the TOP end, once the shock is mounted. Bit of a pain to adjust.
ardykay54
Russ "NeonMan" Knock
Hopkinton, Iowa
22 Kaw Z900rs 50 ann
002718
7581
I touched the wire on an electric fence once..............not the shock you're looking for!:D Russ.
Gymbo
R.I.P. - 2021/08/30
Roseburg, Oregon
892
As a larger guy (over 300 pounds in riding gear) I find the OEM even at max preload is undersprung for me, especially when the bags are loaded for a trip.
2933
Sorry for the typo, $100. Looked up the receipt, it was $115.05 dated 4/15/2010.
*****Yes, the Progressive shock requires removing the right side body panel to adjust spring pre-load but I had the sag set at Westoc one year and pre-load hasn't changed. I do fiddle with the rebound valve when the bike is unloaded.
+1...
If you're not very spirited and/or facing payload issues, a (properly adjusted though!!) OEM shock serves absolutely great for a reasonable price...
