It occurs to me that it's been a few months since I updated this thread. Sadly my ST stills sits in the corner of the garage awaiting a moment of inspiration and motivation to try the next thing. Since the last update I have done a few additional things:
- Left the bike at a local shop (Jett Tuning) with a great reputation. They were able to confirm the cutting out problem but not able to locate it. What they did do was to prove there were no mechanical problems. Compression was 195 -205 PSI and leak down was 5% across the cylinders. not bad for an engine with 150K on it.
- I think I've determined that the problem starts to occur once the bike is fully warm and switches into closed loop running mode. The bike runs in open loop while warming up or at full throttle, conditions where the miss is not present. It also runs in open loop above about 50% of redline. That works out to be pretty close to the 4250 RPM where I experience the misfire. At higher RPM, under deceleration or at constant throttle, the system runs in closed loop mode. The difference between open and closed loop is that the ECM uses O2 sensor data in closed loop. I finally convinced myself to change the O2 sensors. Unfortunately as with everything else, this had no effect on how the bike runs.
- All grounds and ground cap assemblies have been thoroughly inspected with nothing but pristine looking results.
- All the sensors have been replaced or tested, so I am now left with suspicion of a fault in the main harness.
Well maybe replace it with this http://www.ebay.com/itm/05-Honda-ST...ash=item25b253231a:g:V40AAOSwEgVWRPxT&vxp=mtr
