Kevin_56
- Joined
- Sep 3, 2006
- Messages
- 2,453
- Age
- 68
- Location
- Montfort, Wisconsin
- Bike
- 20 R1250RT
- 2025 Miles
- 002300
But to do a "worst case" analysis when calculating the maximum pressure that the moly has to withstand, only two splines engaged should be assumed - 180 degrees apart.
Here we go - Assumed - that word can be broken down into 3 words, to keep from getting this reply axed I will say - it means no facts to back it up. Why 180° apart, why not 90°? Modern machining techniques have a greater repeatably to produce mating parts that will engage the faces of the splines ensuring that the majority of teeth are engaged. 100% engagement, not likely, but more than 6% if only 2 teeth of 32 are touching very likely.
As stated before, there is photo proof of the wrong paste/grease or none is very detrimental to the splines. So regardless of how many teeth are engaged, paste the devil out of the splines with the Honda Moly60 if you have it, or another Moly that has been "tested" by our members here and has not ruined their splines.
