Several years ago I purchased a used set of MCL seat risers from this forum. I'm just getting around to installing them, but not too sure how. I've searched the forum, but can't find installation instructions. Help!
Ahh, you're right, forgot about the fifth bolt. Holds the rear master bracket or?I might have the instructions at home.. but doubtful if I can find 'em.
Pop seat, remove the through bolt that holds the tail end of the gas tank. 5 10mm bolts hold the bracket between the rails. Pull out and replace the vertical nylon pieces with the aluminum brackets. I think there was two pins going side to side, one held on with clips.
Reverse for re-assembly.
Have a look at this thread.Anyone got a photo?
Geeeze Andrew! You have Google-Force second only to Mellow-Wan himself!Have a look at this thread.
