- Joined
- Mar 18, 2006
- Messages
- 2,867
- Age
- 70
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2024 Miles
- 000679
- STOC #
- 2570
Removed
Are the blocks needed to press against the tread to shove the bead on one side into the centre depression - to gain a bit of extra 'slack' on the bead on the other side where the lever is to be inserted ? Or do you use them to press the beed away from the rim so that the lever can pull the slack across by itself ?
Presumably, once started when removing, the rest is quite straight forward.
Do these things need to be bolted to the floor ?
I got a simple Pit Posse balancer, and it works a treat!
Many thanks for all of the input, folks.
The two pinned holders - - how did you sort that out ? Presumably you could drill holes for the retaining peg vertically in precisely the correct location for the wheel. I wonder how they expected it to work ?
The mandrel itself - presumably this has to fit through the wheel bearing ? so 20mm or 25mm for rear and front respectively. The one I linked to says it has 12, 16, 19, 24 mm diameter posts - so I assume 1mm play is OK ?
Or maybe we have not learned to spell.Aha - thanks for the info on that - I found the link eventually. I did look for the info before I posted this thread - which Joe had to move to the correct forum.
Some of us on the UK/USA* side of the Pond seem to spell the word Tyre/Tire* incorrectly/correctly* which result in 0/000's* of results when searched on a USA based forum. (*delete as appropriate). All of which is my excuse for not finding the correct forum and articles when I first looked.
Just for completeness (now I have learned how to spell)
SMSW's review of the HF changer is here: https://www.st-owners.com/forums/showthread.php?160721-Harbor-Freight-Tire-Changer-A-Review
And GregJ's contribution is here: www.st-owners.com/forums/showthread.php?29957-My-no-mar-tire-changer-(HF-Mods)
I do fancy the idea of being able to switch out my own tyres, but I'm beginning to wonder if it might be cheaper to buy a new set of wheels and have one set all ready with fresh rubber for when I want to change them !
jfheath said:due, apparently, to using tyre sealant gloopy compound.
