My SMH10 pairs with my Iphone 6 and I can make calls but it won't stream Pandora or Amazon music. I thought it might be an update issue so I updated the firmware but no dice.
Check your iPhone "Call Audio Routing" found in Settings>General>Accessibility>Call Audio Routing and confirm it is on Automatic. That should also route your music audio correctly to your headset when it is paired. For more help with that, check https://www.iphonelife.com/content/how-to-set-your-speaker-or-headphones-default-audio-iphone
I use Spotify now, but looking at my Amazon music app, I see there is an option to "Connect to a Device" that you will find when you touch the 3 small dots menu icon in the top right of the screen of that app. Try that. I'm not sure about Pandora.Checked, set to auto.
I've done that a couple times on both my SMH10s. Nice to get back to 10-12 hours battery life, instead of 1-2.Not to steal thread... but my Sena 10s are old... and battery finally went belly up & died ( original Sena with coaxial plug )
Was able to replace battery...all good again.
How To: Sena SMH10 Battery Replacement
This old Sena SMH10 workhorse is at least eight years old and never gave me a lick of trouble until it stopped holding a charge. So I took a $15 gamble.www.rideapart.com
I sure hope you programmed it to respond to "Open sesame!"I also installed an Aladdin Connecto Wifi opener on my garage. I am able to use voice commands to open and close the garage which makes riding up to an open garage possible.
Unfortunately, the request to open is "Hey, Google ask Aladdin connect to open/close door." Once that request is made the Genie app replies in a very lethargic sounding voice like it couldn't be bothered.I sure hope you programmed it to respond to "Open sesame!"
