I used this Solar conductive tester to check the internal cell condition.
It's my go to tool when I have electrical charging/battery problems.
Clore Automotive SOLAR BA5
VITAL FOR EVERY CAR OWNER
The Clore Automotive SOLAR BA5 Electronic Battery Tester is an ideal solution for every car owner. The device is suitable for testing most types of 12V batteries. You'll be able to check the condition of wet batteries (including maintenance-free), AGM (flat plate, spiral wound), gel cell, and even deep cycle batteries. The SOLAR BA5 basically belongs to conductance testers that apply an AC voltage during the measurement. An important feature of the tester is that it's capable of indicating the cold cranking amp level, therefore, to find out the estimated lifespan of the battery is no longer a problem! The tester allows you to measure amperage capabilities in the range from 100 to 1200 Cold Cranking Amps, so it'll be suitable for most modern car batteries!
SIMPLICITY AND USABILITY
The tester offers a really incredible ease of use. All readings are shown on the digital LED display, it doesn't matter where and when you will carry out the testing—the display will provide you an optimal viewing. Additionally, you'll be able to select the CCA rating to obtain the most accurate readings! A simple navigation via a few buttons will allow you to select among CCA, DIN, IEC, EN, CA standards depending on the type of an accumulator. Special indicators under the display will help you assess the condition of a vehicle battery based on the achieved data. Additionally, the tester provides pass/fail LED results, so, it'll be a piece of cake to determine whether the battery needs to be replaced.
The SOLAR BA5 is an ideal choice to settle on. An excellent compatibility with a large number of batteries, reverse polarity as well as a comprehensive protection against overloads makes this car battery tester a versatile solution for any self-respecting car owner.
