st11ray
I just got a USB charging port. Where are you guys mounting them? I'm going to run the wires back to my auxiliary fuse block under my seat. This is the USB port that I got.
It's got a volt meter on it so I'm thinking of maybe on the speaker grille on the left side. I wouldn't be able to see the volt meter if it's in the fairing pocket.Front pocket (?)
I've got my driving light switch there. I thought about putting the USB there but it's such a pain disconnecting my driving light switch everytime I remove the fairing. Plus I would have to put it on the right side because I don't have room on the left with my other switch. This is on a 1300.I have a very similar one, also connected to my auxiliary fuse block under my seat. It's mounted here (blue circle, but that's not my bike)...
I typically check the voltage just after starting and sometimes when running down the road (14.1-14.4V). This mounting position allows me to run USB cables from there up inside my tank bag. To be honest though, I don't use the USB much as I generally just keep a high capacity battery pack in my tank bag... my phone and extra Sena are plugged into that, especially when raining.
That is some slick little kit! I like it! That's going to go into the Box of Farkles That May or May Not Get installed. A lot of these type units look cheesy but even close up it looks well done. Thanks for posting!I just got a USB charging port.
Do you have a picture of yours?I mounted a very similar one in the left grill. Works good there although reading the voltage is difficult because of the angle of sight from the seat. One of these days I am going to get around to making a couple of spacers out of PVC pipe so that I can angle it up a bit so it is easier to read.
I will get one a post it. Bike is in winter storage so it may not be for a day or 2.Do you have a picture of yours?
ThanksI will get one a post it. Bike is in winter storage so it may not be for a day or 2.
that's where I put mine. That way, it's out of the weather. The only prob was vibration, so I rubberbanded the plugs to the port.Front pocket (?)
Did you use a hole saw to cut your hole or what?Here are some pics of mine. I have also mounted a regular cigarette lighter plug in the right grill.
A couple of things to keep in mind.
1. mount the rubber cover so that it hinges from the bottom otherwise you will not be able to see the voltage reading.
2. reading the voltage reading from the seat is nigh on impossible with mine due to the angle and how the reading is recessed. Like I mentioned, I am going to see if I can make some asymmetric spacers and get it angled up enough to read while seated.
3. there is more room behind the grill above center than below, that is why they are not mounted in the center.
I liked the grill placement because there is ample room behind it for wiring and connections.
The round rocker switch is for my fork lights.
Sorry for the out of focus pics. Pretty dark in the storage area.
A hole saw would be the best way to do it. I did not, because I dont want to cut the bike up. I just lay mine on a rag in the left pocket.Did you use a hole saw to cut your hole or what?
Yes, I used a hole saw. IIRC, a 1" works fine. Just run the drill slowly, and go gently, so it doesn't tear the plastic.Did you use a hole saw to cut your hole or what?
Or high speed, but dont press. Let the tool do the job. Make sure the plastic is warm and the hole saw is sharp. I spent years working w plastic. Clamp the piece u r drilling on a piece of woodYes, I used a hole saw. IIRC, a 1" works fine. Just run the drill slowly, and go gently, so it doesn't tear the plastic.
