Article [13] ST1300 - Rostra Cruise Control Installation
That's on my list, complete with the requisite GoldWing pod.
Meaning, I have not done this yet.
However, it would seem that you want enough cable to allow lock-to-lock handlebar movement, but not much more than that.
I've read this entire thread shortly after joining, so I will have much to revisit.
Which specific cable are you referring to in the GW switch?
I foresee following the path of the existing cables coming from the right grip, just bundling them together as best you can.
I plan on following the path of the existing cable(s) and the lock to lock requirement will certainly be met. The entire cable could possibly be shortened depending on where the connector(s) I'll be attaching to is located. I haven't had to tear the bike apart yet so I'm not sure of the location of those connectors. If they are under the tank, the entire harness from the switch could be shortened and I'm just trying to get an idea by how much. I've got nine-pin connectors and a few others that I'll use to modularize the whole assembly. I could use single-wire spade connectors or bullet connectors, but I like neatness and organization in my projects.
Just make it the same length.
I'm assuming you mean the same length as the existing cable and therein lies the rub. I can't measure the existing cable without removing it from the bike. I was hoping to assemble the new terminals ahead of time so all I would need to do is stuff the terminals in the plug to match the correct pins in the plug on the wire loom.
Gotcha. That is what I meant.
Maybe someone here has an OEM switch pod off a bike they can measure from housing to plug.
For the 1100 I cut off about a 1.5 ft.. now I did have to change some pins around. I would suggest you wait with it so you can do a proper measure and match the wires. I left the harness for the cruise control section alone, meaning I didn’t shorten it. If you have the tools and the connectors it’s not going to take you long on the day of the install.
ok ST gurus, I got my Rostra in, stripped the bike down, and ordered a GW switch plus a AT&C pulse devider. Im going to use 1500 gw throttle cables (6" longer) has anyone used the atc devider? the z063 was out of stock
I used the F6B GL1500 control and the cables that came with it.
The cables are too long, I had to make a few "S" curves to make it fit.
I used a replacement for the divider listed in the article, it was for a taxi.
I had to move the brake master cylinder all the way foreward,
I made a spacer to fill in the gap at the end of the hand gripe where the handle bar weight mounts.
Be careful and position the control so it does not hit the fuel tank, very carefully drill the new hole for the locating pin,
Measure and jig it up several times before drilling!!!
How much longer were the f6b cables? I ended up using a lighted gl1500 control assembly, had several laying around. But since i swapped my bars out too I could use longer cables. I went w the wing pull cable (about 6" longer)
With out measuring, I am guessing 4-6 inches.
I have a full sweep in the area from the throattle bodies to the right side frame member and out the exit foreward.
I also have a fairley large radius in front of the tank to the grip.
I used the cables that came with the cruise control grip.
No problems so far.
It basically provides easy access to different switched hots, ground, and the turn signals.
I'd say the signals were included for a trailer, but there are no tail- or brake-light wires.
This is what plugs into it, a 'quartet harness'; it has three load sockets and a feed-through:
I always wondered why Honda included the turn signals in that harness. That harness was used for the available factory heated grips and radio as far as I know, so no need for turn signals in either of those applications. Maybe it included the turn signals for use on the police version?
Or for some type of police equipment with its own signals, like a different fairing or top-box.
Also the 12V accessory outlet for the right fairing pocket, I believe. I'm guessing it uses the red 3-pin connector. 08V70-MCS-100
Here are a couple of pics stolen from a current ebay listing.
I'm currently installing the Rostra cruise control into my motorcycle and using a different switch, I am trying to figure out which wires to use for the functions below.
Rostra CC Wire -> Bike wire
Red Brake Positive -> ??Green with yellow stripe on right hand connector off of switch cluster?? (Front brake lamp switch)
Violet Brake Negative -> ??Grey with green stripe on right hand connector off of switch cluster?? (Front brake lamp switch)
Dark Blue Tachometer (TACH) Wire -> ??Yellow with green stripe on large left hand connector?? (connects to the instrument cluster tach 0 to +5vDC)
Gray Vehicle Speed Sensor (VSS) Wire -> Pink with green stripe on large left hand connector
Light Green Neutral Safety -> Green with red stripe on large left hand connector
The first 3 wires I am unsure of as I found the wiring diagram in the PDF of the Rostra CC install article a bit confusing given I am not using the goldwing switch.
The other wires I found using the wiring diagram here (this is a god send!)
So I believe after a LOT of digging I found which wires goes where/does what.
While testing in self diagnostic mode, everything checks out except the VSS signal (I think?). When I rotate the rear wheel, the LED blinks (yay!) but then it never stops blinking slowly...
I have tested with various gain settings on both the cruise control module and the signal divider, I verified that I have proper ground connections, power connections and the wires from the VSS connect to the divider and then the CC module. I even connected a multimeter and verified I am getting an expected voltage from both the output and input wires as well as I can register a frequency on my meter's Hz/frequency setting.
Dip switch settings are:
Cruise Control: Extra low gain, 38600 pulses, 4 cylinder/low, Square Wave Input, Manual Trans, Open circuit controller (which mine is)
Pulse divider: High Gain, divide by 2 (I have tried both with capacitor C8 removed and installed)
I would greatly appreciate some insight on this, when you tested your unit did the diagnostic light stay flashing? Any other suggestions of things to check?
Do you have LED taillights? They don't have a low-enough resistance to convince the Rostra that the brake-light bulb is functional.
Also, the engine settings tell the Rostra about the veghicle's power-to-weight ratio. You should use higher settings, such as 6- or 8-cylinders and higher power, and more gain.
That’s normal operation for my units. I have to turn off the ignition switch to stop the blinking light.
I can’t answer your other questions as mine is installed on a ST1100 and a Suzuki VStrom 650
