About engine revs. Yes, at low revs there’s little power, especially in a high gear, BUT, if your just cruising through a village or small town with a 30 or even 20 mph limit, you don’t need any power; there is absolutely no need to be spinning that motor up over 3,000 rpm, let it relax. These things will happily trundle along flat ground at idle IN FIFTH! Sure you won’t be cracking the throttle open in that condition, but you’re giving the engine a rest, saving fuel, and making a lot less noise. It’s also very relaxing, for you, your passenger, and pedestrians you pass. It also makes you look like a responsible citizen and not a hooligan. No one wants to hear a bike ringing it’s nuts off in a 30 mph zone. It’s also very immature. There’s also the issue of piston speed and the greater concept of mechanical sympathy. Why do certain racing drivers always blow up their cars and others always manage to nurse them to the finish? Mechanical sympathy; realising that what you do to the engine, has consequences. If you’re always in too low a gear, your piston speed is unnecessary high. No mater how well the motor is made there are only so many piston revolutions in it before wear becomes apparent. Why cruise at 3,500 in third when you could be doing 2,000 in fifth?…Mechanical sympathy. I’m not suggesting that lugging it everywhere is the answer, in fact lugging it is bad too (highest gear that is appropriate, does not mean lugging), just that, like a car, you should be in the highest practical gear for the conditions and your driving needs. Cruising? relaxing, riding respectfully through town? Keeping your noise down? Switch up those gears and let the engine relax too. Feel the need for speed/rapid acceleration? Snick it down a couple of gears and let her rip. In fact it’s the amazing tractability of these engines (power everywhere and not just at high rpm, like a 600 four) that makes this my “go to” bike for everything. I have a 650 thumper which is much lighter, and flickable and easier to pick up, so it should be my first choice for simply “going for a ride”, but that engine won’t pull cleanly below 2,500rpm, and prefers 3,000. That’s 1.400 to 1,900 higher than where my ST can waft along almost silently in fifth. So, when deciding what to ride, I reach for the ST. Despite its width and weight, it’s still the preferred “exploring “ bike because of that wonderful tractable motor.
Here’s another reason for riding in the highest gear possible; less snatch. If you hit a pothole or bump which causes a rotation of the throttle. Also when exiting a closed throttle corner, less snatch when the fuel injection kicks in. This is especially important if you have a passenger, because they get thrown around much less.
I know I’m going to get flamed for this post. So let me end in saying, when I need to move rapidly, I have no problem snicking it into 3rd or even 2nd and whacking the throttle open. Revs are not my enemy, just revs where they aren’t needed. I don’t need a dyno chart to know where my power is, in fact I discovered there’s a distinct power band from about 5,500 to red line. How did I discover this? Slipping clutch under hard acceleration ( yes, I know it will need changing soon, I have the parts already. )
