Keyless ignition
Tcmcnomad
Macon Georgia
I will go ahead and ask. That whole handlebar set up does not look familiar at all. Can't see much but I don't believe that's the hellibar setup and that switch pod is not ST1300. Can you share some specifics? It looks like a cruise control setup on the throttle side, yes? Interesting
$39 Oxcart adjustable bars, currently I'm running a 250 mm Center bar, 310 mm grip tubes filled with copper shot with rubber cement plugs at either end to reduce vibration.
$40 5.5" pull back risers
Cockpit view
Goldwing 1500 cruise control switch assembly. Wired to Rostra cruise. I've seen folks use the 1800 because it matches astheticaly but the 1500 uses the same plugs as the ST making it plug and play.
These are extra sweet, $100 budget radial levers, tons more modulation
P.E.I., Canada
2005 st1300
Cockpit view
Very cool. Brembo masters, correct? Is there a lot of improvement with those Master cylinders over stock? Is the rest of the brake system stock?
Interesting.. I never knew that handlebar system existed
Tcmcnomad
Macon Georgia
And a cigarette lighter, yes! This is badazz. What is the item circled in yellow?
That is a 4 prong accessory mount that I use mainly for a waterproof GPS/phone case. But it can also be used w a lot of phone clamps etc. IMG_20230217_182949220.jpg
1. Garmin edge 1000 bicycle computer (extremely precise, track recording)
2. Phone (1 of 3 I carry on rides) precisely originally mounted to the handlebars so I can take perfect spotwalla pictures of the receipt and odometer with it without removing it
3. Waterproof pouch
Tcmcnomad
Macon Georgia
Best I can tell these are identical to the brembos exc these are $100 a pair vs $300 per
