I have been plaguing the forum recently with questions about zmoons and wiring. Thanks to advice from
@Uncle Phil and
@Andrew Shadow success is mine (OK their's). Now before you all say so what's so clever about that? you have to realise that I hate working on bikes. My idea of motorcycling is get on... turn the key... and ride. Yes, I can do the basics and a little more with the sidecar, cos there aren't any sidecar maintenance guys around, but overall I don't get any real satisfaction from fiddling with my machines
However, in this case, and as I'm recently retired and have plenty of time on my hands I thought I'd give it a go. So off I went. To make my life easier I had also purchased the zmoon harness. Interestingly, the blurb from zmoon just say plug the loom to the battery and connect the lights
Even I know that's not a good idea. So a waterproof relay and fuseblock were purchased and away we went.
First thing was to figure out where I wanted the lights to go. Lots of the group fasten them to the forks where the reflectors go, but UK models don't have the reflectors and if I'm honest I didn't like the look. I was aiming to create the famous light triangle, so looked at the top of the tip-over bars covers but again they looked unsightly. Eventually I decided that they should go under the covers. Then, how to mount them using the existing cover retaining bolt (different positions on each side on my 2000 solo). Ended up using two L bars (currently from a furniture assemble kit
, but two more rigid and better suited L bars are in the post).
Next, working out a route for the loom, there is an excess of cable, but with the provided relays/fuses placed in the underseat storage, simply looped it up the left hand side of the bike around the air filter and back down the right hand side.
Now came the, to me, complex bit, so bite the bullet and fit the relay and fuseblock. Everything loose, battery and axillary feed pulled away from their homes and off I went. In-line fuse from battery to relay (plus connection to auxillary feed), then followed the previously received advice, wired in the fusebox. All untidy, just making sure I had lots of space.
Just previous to this this point I had to relocate the power source for my dash accessories (satnav, temp/voltage display, dashcam and Pure 200 DAB adaptor), currently hooked up to the accessory power feed. Expensive items disconnected this was the first attachment to the fuseblock....
Fingers crossed, turn on the ignition.... and it worked
Now to the lights. Annoyingly, although the loom comes with female connectors for the lights, the lights come with... just wire... I know its only a few male connectors to be fitted, but really!
Anyway, connection made and ..... they worked. However, the loom comes with a four way illuminated switch that definitely didn't look waterproof so I replaced it with a 3 way unilluminated motorcycle switch off ebay. Fitted to the right of the handlebars.
Now, tidy up that mess. The relay went into the perfectly sized space underneath the main fusebox, secured with velcro (another brilliant idea stolen from
@Uncle Phil). The lighting relays/fuses into the underseat storage, again secured with velcro. The fuseblock to the rear of the storage (you'll never guess what is is secured by
) and my Autocom intercom box. with more velcro secured to the side of the storage area.
Now this should be the end of the story... However, having done all this, I was pondering... I would actually have liked to have both independant use of the lights AND the option of having the yellow light be replaced by white when I used Main (High) beam.....
So if a relay is just a remote switch, could I... yep, I thought, just put a relay in the switch wiring linked to the main beam.... so I gave it a go with a 5 pin relay I had lying around in the garage. It worked.. but where was I going to stick that big bloody relay... Google search and Amazon came to the rescue...a micro relay...
Once again, some tidying up and routing of wiring and we have light. And all because of and thanks to this forum!!
