Passenger floorboards - who has used any on an ST1300?
Ferret what year are your floorboards from? I just want to make sure I get something that will work well.
Do you think these would work?
FleaBay Floorboards
Well since we made them 11 years ago, and I got them from a buddy that had put larger floorboards on for his wife I'd say they came from a 2008 or older wing, although I don't think they changed the wings from 2002 on or something.
SMSW is right that set doesn't have the pivoting bar, necessary to make them folding.
Went ahead and pulled one of the floorboards, and took some pics and measurements, so adding some more pics which may help someone
Don't suppose anyone saved these photos? I acquired a set of gl1800 floorboards this weekend and would like to fabricate this bracket set.
TIA, Damon
Yes, Goldwing 1800 floorboards on home-made brackets. I had a tute on here at one time.. maybe in the archives some place? but the bracket is just a piece of steel flat stock 1 1/2" wide x 1/4" thick x 5 3/4" inches long (with 2 holes that bolts to the back of the Goldwing Floorboard) with a nub of 3/4 square stock welded to it with a hole drilled thru it for the peg pin. They mounted into the stock footpeg bracket with the stock push pin. They even folded up and down.
Folded up
You can kinda see the bracket in this pic
folded down
OH, man. I cussed myself about this a couple days ago. I found them on a bench in the garage all but forgotten about. I've been working on a 1990 CB-1 and it's been taking most of my spare time. I'm going to try and get on it this weekend.
I just made up a drawing from memory for the bracket you need for the Goldwing Floorboards. The 3/4" nub may not be straight up and down it may have to be rotated, I can't remember but it's a piece of steel plate 5 3/4" long by 1 1/2" wide by 1/4 " thick with a 3/4" bar stock nub with a hole drilled thru it for the pin welded to it, and the plate has 2 holes drilled in it to match up with the mounting holes on the Goldwing floor boards. Hope this helps.
