Old Enough To Remember?
Did it work as well as their 'heater'?
Actually just lack of care/maintenance... :unsure:
The heater channel hoses inside the A-column were paper lined... dew from the windscreen could run down there through the defroster nozzles in the left & right lower corners, causing the paper to de-laminate and collapse, thus clog the elbow in the air-duct running inside the sill behind the front wheels (ergo foot-well: full blast, windscreen: nearly zero air flow)...
On my '71 (already equipped with the "ventilation-croissants" behind the rear side windows) I simply thoroughly cleaned out all the offending paper bits (shop-vac and a piece of welding-wire with a hook bend at the tip to break/dislodge stubborn pieces), installed new hoses inside the A-columns and voilà: never needed so scrape ice again, ever... :cool:
Max heat with full air-flow on the windscreen, right from the second that engine fired, whilst liquid cooled require a few minutes to warm up the water-jacket; even worse on 'modern' cars which prioritize fast raise of engine temp over cabin heat due emission regs...
... anyone in for some nightmares...
My dad had the exact same equipment in 3 rooms of his dental office, until 1976 when he retired. I grew up playing with the foot operated chair lift and the belt driven drill. He drew the line, when it came to playing with his X-ray machine.
... the belt driven drill.
I can remember being tortured with those old, rumbling "hammer-drills"... :rolleyes:
Current, modern equipment is soo much smoother and also the dentists have changed their approach from blunt "oil/mining drillers" to surgical precision...
