increasing
Dekkreparasjonssett - Dekk reparasjon og lappekit - thansen.no
Kjøp Dekkreparasjonssett : Dekk reparasjon og lappekit hos thansen.no
I wouldn't recommend anyone do that, get the screw out and plug the tire and you'll avoid any surprising situations.Some times the best thing to do is leave the screw/nail in the tire and pump it up, depending on how fast or slow of a leak. Myself I carry can of sealant/ worms and a small 12 volt compressor. But I have also fixed a tire with Ultra black Sealant by Permatex, waited a day before filling the tire with air. Tire held air till it wore out.
Though I agree with checking pressure before each ride, that does not protect you from a subsequent puncture during said ride. That’s why I run a TPMS. It gives an early warning of a puncture sustained in route.Good Judgement should always be used, I do agree ,get the leak fixed as soon as possible. OP asked if anyone has used an Amazon product. In the middle of nowhere is not a good place to try it out. Lack of air pressure is going to do more damage to a tire then the screw or nail left in till you get into town. Myself I don't like fixing stuff on the side of the road. Good reason to check tire pressure before every ride.
Seriously been thinking about getting a TPMS for my bike, question is what brand and how accurate are they.
I agree with what STGui wrote above. Having an accurate TPMS is desirable but not the most important feature. Once you have determined the variance, it is more important that it be consistent in its indication. The consistency is what will allow you to know that something is wrong when what it indicates suddenly changes significantly and you know that you can trust that change in indication.Seriously been thinking about getting a TPMS for my bike, question is what brand and how accurate are they.
The dried out gummy worm fixed the hole on the first try.
Yeah, I’ve never replaced a plugged tire until it was worn out and needed replacement anyway. I had an incredibly bad run for a few years with multiple punctures in both my bike and our cars, I must have done 20 plugs over that period! One rear tire had four plugs in it by the time it was worn out. I’ve done just a few since and a few before.Though I haven't tried any other method I had occasion where a nail punctured my tire at a 45º angle and a gummy fixed it first try as well. To this day I regret replacing a nearly brand new tire that a buddy plugged a few miles later out of fear the plug wouldn't hold. Lots of fresh glue and let it sit overnight and it hadn't lost any air. Who knew. I didn't.
I Don't think I will try to get this tire patched or plug it myself. Unless I have to take the rear tire off the wheel for some other reason, prematurely. But meanwhile I'll just monitor the situation with my new TPMS that arrived from Amazon the other day.
Thats what i use. I ran battleaxes and the sidewall saved me every time. I had five plugs in my rear on my first tour. Ifoolishly stopped kn a lot of safety zones for pics.I’ve use the rubberized rope/worm type plugs as pictured here several times.
View attachment 374991View attachment 374992
And I agree they generally work on my car, but the one time that I thought it would work on the motorcycle (and things seem to go well during the plug job at a gas station) that tire still had a leak that required two air pump stops over the next four hours before I got home.
Also, regarding my car tires, one time I pulled out a very small nail (or actually I think it was half of a staple— a commercial staple that wood trim and cabinets would be assembled with) and that hole in my tire was such a small diameter I could not force the reaming awl through the hole to widen it out and roughen up the hole for the gummy worm type plugs.
I had to use a cordless drill on that staple hole.
The smaller size of the screw-in tire plugs look like they would be the most useful kind, because they will accommodate small holes which resist being reamed out with manual force. I’ve generally got pretty good hand, arm, and upper body strength, but a couple times it was very difficult to ream out the hole,
and one time it was
impossible for me to do it.
