Yeah... I did wonder about that serious case of neglect and abuse though...Yes, that works until the center falls out and all you have left is the left hand race.![]()
What I've read some will do is dremel out two notches on the inside of the wheel to allow a punch to contact the race prior to installing the new one.That bit of kit will be coming soon to Uncle Phil's ST1100 Repair Shop (just ordered it) - that looks good!
With a Dremel cutoff wheel and a cold chisel I finally got it 'extricated' without too much damage to the wheel.
It's such a tight fit and a small steel race setting in an aluminum housing that welding could get a bit messy.
I did think about that - or drilling a punch hole so you could get to the back.What I've read some will do is dremel out two notches on the inside of the wheel to allow a punch to contact the race prior to installing the new one.
I swapped the rear wheel when I converted RedBird to an ABSII.Yeah... I did wonder about that serious case of neglect and abuse though...![]()
Totally agree, try to have tools that are used often of good quality. I have bought a number of tools that have never been used or some have been used once, these are tools bought on AliExpress, Temu, Biltema and similar stores.Sounds like Phil and I have equivalent thoughts on cheap tools. I've used mine 2-3 times and those times I was in a jam and they saved me; they have given me value at their (low) price. Everytime I've used them I figured this will be the time they break (their design is such that a lot could go wrong in the hardening or metallurgy in a low cost factory), but so far so good. If I was using them regularly I would lay out 4 times the money for somthing like the bearing pro tools @increasing linked above. They look like a better made/longer lifetime tool.
IIRC, the ST1300 steering bearings recesses have such notches from the factory.What I've read some will do is dremel out two notches on the inside of the wheel to allow a punch to contact the race prior to installing the new one.
Smart solution, then there will never be a problem againSpeaking of notches, if you’re just removing the first (intact) bearing, it’s easy if the previous time you modified the distance collar like this:
PVC pipe used for illustrative purposes.
I had one of those from the last time, but the race would not budge at all.IIRC, the ST1300 steering bearings recesses have such notches from the factory.
Am I missing something? Seems to me a drift with a 20 degree bend near the tip with the tip ground to catch the remnants of the outer bearing shell would do the trick. Before the invention of the STOC stem bearing R&R tool kit’s race remover, Mike Martin removed his with a bent piece of rebar with a tip ground to fit. Phil’s remaining shell looks to have a lot of surface to catch/drive on.
Thanks, John! This is what I remembered seeing. I've yet to do mine but I have a tire change coming up. Will Def make this mod when I do, though I doubt I'll ever need to replace it again after this.Speaking of notches, if you’re just removing the first (intact) bearing, it’s easy if the previous time you modified the distance collar like this:
Edit: put the notches on just one end, the left side. So you remove the rear wheel’s left side single-row bearing first. Then you’ll have full access to the more-difficult-to
-remove right side double-row bearing with the distance collar now removed.
John - But will that help if there's only the race left since the race is 'protected' by the way the wheel is constructed?Speaking of notches, if you’re just removing the first (intact) bearing, it’s easy if the previous time you modified the distance collar like this:
Front or rear? The ST1100 rear is pretty solid with a ball or two missing ... or so I've been told!The last "failure" I'd observed was on ze GF's NT700VA right after we'd obtained it...
Entering a ramp and the front end made a sudden jerk upon leaning in...
Straight to the shed... and indeed, one of the (aftermarket) wheel bearings felt rough and had <1mm play...
Replaced with OEM set and all fine ever since...
So as <1mm play already causes such a jolt, I do wonder how folks ride on till the balls fall out without noticing...
I'm a bit anal on those, inspect smooth rotation and replenish waterproof grease behind and on the seal upon every time a wheel comes out...
I've told this story before. A gf I had when I was in my low 20's drove down the freeway at 55-60 mph with her left rear wheel sparking on the pavement - she had shredded her tire and the rubber was completely gone. The only reason she stopped was because a young guy pulled alongside and waved her over to the shoulder. She later told me 'I thought the car was handling differently'. Neither the handling, sound or rooster tail of sparks was sufficient to make her pull over on her own.I do wonder how folks ride on till the balls fall out without noticing...
Front... and on a straight piece of road indeed only a slight fuzzy feeling on the handlebar, but a bit scary upon throwing it into a corner... <1mm play in a bearing multiplies to ~1" offset at the outer circumference...Front or rear? The ST1100 rear is pretty solid with a ball or two missing ... or so I've been told!![]()
