It wasn’t just the windscreen adjustment because I explored that and luggage and suspension preload and tire choice and pressures trying to zero my 2005 in remove or minimize the onset. I was under 5’ 7” while riding my 05 and I always had the windscreen all the way down or at most up about an inch and a half. It is a complicated issue. Perhaps not all 1300s did it. I think that the combination of aerodynamics around the blunt front fairing and somewhat flexible aluminum frame set the stage for an oscillation feeding the weave. RIDE found something like 4 to 7° of yaw and roll measured at the luggage rack. It definitely isn’t something that starts in the forks going back-and-forth. I’m a light rider never weighing more than 165 pounds geared up and besides running max rear shock preload and the correct fork spring preload (for my weight) the factor that did the most to minimize it was replacing the OEM caged ball bearings in the head stock with tapered roller bearings. Of course by that time my bike had 96,000 miles on it and I don’t know if it was just learning the correct suspension settings by then or the steering bearing preload or both that “fixed” the weave.I've always felt that it had something to do with the position of the windshield and creating aerodynamic lift.
To me it felt like trying to drive an old pickup truck with too much weight in the back and the front got 'light'.
When I dropped the windshield all the way down I did not encounter the problem regardless of top speed.
The nice thing about that section of the Autobahn I was on I could triple digit as long as I liked without fear of a ticket!
And I would still often be passed ....![]()
The one I was on was headed for 'police service' before the ruckus started.It wasn’t just the windscreen adjustment because I explored that and luggage and suspension preload and tire choice and pressures trying to zero my 2005 in remove or minimize the onset. I was under 5’ 7” while riding my 05 and I always had the windscreen all the way down or at most up about an inch and a half. It is a complicated issue. Perhaps not all 1300s did it. I think that the combination of aerodynamics around the blunt front fairing and somewhat flexible aluminum frame set the stage for an oscillation feeding the weave. RIDE found something like 4 to 7° of yaw and roll measured at the luggage rack. It definitely isn’t something that starts in the forks going back-and-forth. I’m a light rider never weighing more than 165 pounds geared up and besides running max rear shock preload and the correct fork spring preload (for my weight) the factor that did the most to minimize it was replacing the OEM caged ball bearings in the head stock with tapered roller bearings. Of course by that time my bike had 96,000 miles on it and I don’t know if it was just learning the correct suspension settings by then or the steering bearing preload or both that “fixed” the weave.
I'm still trying to work up the nerve to get mine out of first gear!Had my 2006 ST 1300 for 10 years and 110,000 miles. Guess I never went fast enough to make it weave ..what a wuss I am.
I think I watched a different version of this episode. He was rather complementary to the 1100 pointing out the differences between the 1100 and 1300, the geometry of the two, the differences in handling…I thought he was impressed with the timing belt and the power the 1100 had. Unfortunately pulled up the one article one pulls up on every google search for a 1300… it would have been better if he debunked it, that would have made it a better video. However here we are…..
I wish the owner of the 1100 had replaced the right bulb of the headlight before filming it, other than that looked like a nice 99-02 ABSII.
It was a North American ABSII, from the colour, a 1999-2002 model year, filmed on the West Coast. Intermixed with the video was pan events from Europe. It was brief. In that archival video were examples of Pans from different countries that either had both headlights illuminated or just one.I didn't watch the video as I don't care for most of his videos.
As for the headlight, different countries have different rules about headlights. Was it "stock" internet video from who knows where or did he video it?
That footage is actually nicked from early, official 'Honda Pan-European Rally' videos (VHS era, YouTube) which could bear copyright issues as well...Intermixed with the video was pan events from Europe. It was brief. In that archival video were examples of Pans from different countries that either had both headlights illuminated or just one.
Some of those few places are around Amarillo where you can light it up for miles of straight smooth pavement with no trees to obscure line of sight. And no troopers.As I have said many times, I have experienced the ST1300 'Pan weave' on the Autobahn in Germany.
The key is I had to reach 120+ mph sustained not just run up for a little while and back down.
http://www.unclephil.us/Alps2008Day04.htm
And there are very few places in the USA where you can do that - maybe out in Nevada (or so I've been told.)
Loading, top trunks, tire inflation, etc. all affected it.
But I don't believe the officer that died testing the ST1300 was a 'rookie' rider by any means.
Mr. Google again -
- Tests confirmed that the "Pan Weave" instability could be reproduced in civilian models at high speeds under certain conditions, with some civilian owners reporting experiencing it as well.
BTDT on my ST1100s - and they didn't weave a bit!Some of those few places are around Amarillo where you can light it up for miles of straight smooth pavement with no trees to obscure line of sight. And no troopers.
Excellent for "What'll She Do?"
Stop by sometime and I'll give you the tour.
