Confusing indeed...For NT700?
Sorry everyone, it’s for a ST1300 OEM mount.For NT700? I think they have their own site? If no answer, try there?
Have a look at the attached. One is the ST1300 top case installation instructions, the other is a schematic that shows where each part goes and in what order. Maybe they will help you sort it out.You didn’t need spacers here?
I remember when those installation instructions also covered the part numbers for every single nut, bolt, washer, rubber grommet, etc...One is the ST1300 top case installation instructions...
I may have a set of instructions and paperwork, give me a bit to find them.Sorry everyone, it’s for a ST1300 OEM mount.
BTW, I know my avatar shows only a NT700 (which is the source of confusion), but I’m embarrassed to say I’ve tried twice but I can’t figure out how to change it to add my recently acquired ST.
Also……. I haven’t been able to find any instructions online on the exact order/sequence of all the washers, spacers etc. I think I have it figured out, but the one thing I don’t quite get is why there’s only 4 spacers, and not 6.
Thanks for the instructions you sent me, Larry. And thanks to everyone else for the help.I may have a set of instructions and paperwork, give me a bit to find them.
I thought I had it mounted correctly until Igofar sent me the attached instruction sheet. AND IT SHOW 2 ADDITIONAL SPACERS!!!
I assume those spacers are there simply to “level” the box on the mounting plate. And I already did that with some spacers and washers I had laying around. But
why aren’t they depicted anywhere else? And they aren’t included in the mounting hardware kit.I thought I had it mounted correctly until Igofar sent me the attached instruction sheet. AND IT SHOW 2 ADDITIONAL SPACERS!!!
I assume those spacers are there simply to “level” the box on the mounting plate. And I already did that with some spacers and washers I had laying around. But why aren’t they depicted anywhere else? And they aren’t included in the mounting hardware kit.
