Check the axle spacers both sides. Note that the spacer on the left (clutch side) sticks out from its flange only 4mm.
See my recent post #36 in this thread for pictures
https://www.st-owners.com/forums/th...ings-what-the-manuals-dont-tell.157453/page-2
Take no notice of the photos in the post above my post in that link - they are wrong !!
Then slacken everything off - 4 pinch bolts, and main axle bolt. Redo it:
Push the axle in from the left so that the end is just about flush with the axle hole on the left fork.
Hold the axle bolt with the correct size allen driver **, and tighten the front axle to the correct torque.
** If you haven't got the hex driver, then temporarily tighten the left hand (clutch lever side) axle pinch bolts to prevent the axle from turning while you torque the axle bolt. Then slacken the left hand side (clutch lever) pinch bolts again.
Tighten the two right hand (brake lever side) pinch bolts to 22 Nm. Tighten both to 20Nm first, then tighten them both to 22Nm and repeat, alternating from one to the other. That is because when you tighten one, it removes the load from the other and it becomes slack.
Now bounce the forks. The left hand fork should sit so that the axle is flush with the axle hole in the fork leg. If it isn't, manoeuvre the fork leg so that it is. If it is a long way out - then something is wrong. Find out what it is.
Tighten the left hand fork pinch bolts in the same way that you did with the right hand side.
Check the clearance where the brake disk passes through the caliper bracket. It should be at least 0.7mm on both sides.
If it isn’t, then something is seriously wrong. After bouncing the forks, my left fork is always flush with the end of the axle bolt - that is its natural position.
I’ll post my animation link here as well. It’s a bit of fun, but it illustrates the point. Best viewed in full screen mode.
