This, just like tail light bulbs in an older car. You can swap the indicators to LED as well, but you just need an LED flasher which can be obtained online (like superbrightLEDs.com- that’s where I got mine).The sockets remove from the back, under the seat, twist and pull.
My turn singnals flash four times when the brakes are applied, if you are turning and using a turn signal they don't both flash. What I'm doing ( if I ever get the cover off) is replacing the brake bulbs with LEDs that will flash when the brakes are applied, the bulbs are kind of spendy, $29.50 apiece.This, just like tail light bulbs in an older car. You can swap the indicators to LED as well, but you just need an LED flasher which can be obtained online (like superbrightLEDs.com- that’s where I got mine).
goto page 68 (76 of *.pdf)....Squeeze the two side flaps inward towards each other, and the flap will fold down.
