Purolator PL14610 vs Purolator ML16817
A quick search found Walmart's pricing for both - ML = $37.13/3 and PL = $25.22/3. Both prices were for 3 filters
Menards has been my go to for filters. the PL is $7.11 each but you have to do their $^%#&-ing rebate program. They are always holding some of your money. The out the door price is $7.99....with 88¢ rebate available on the next purchase.
Just bought the PL14612 at my local Menards $7.99 + tax, doing the oil change this coming weekend. Have been using this filter for the past two years. That plus the one gallon size Rotella T6 15W40 full synthetic, brings the oil level to the middle of the sight glass :). Total cost $34 compared to $60 plus with the Honda oil and filter.
Probably none, if oil and filter was changed on a somewhat regular basis.
A good friend, who owned a Honda power sports store, said they never saw an oil related engine failure that wasn't due to simply lack of oil in the 25+ years he owned it. He remarked that, if it wasn't for plastic sales, they never made much money on Hondas once they were sold.
Just curious —- is the Honda ST oil filter a take off of the ever so common and economies of scale Accord. Civic ( etc) 15400-PLM-A2.
The puolator above gets cross referenced to Honda oil filter - the two Honda filters allegedly have different bypass pop pressures:.
The below listed filter looks like it may be the Honda filter intended for the ST(?)
AI Search…..
The Honda 15400-PJ7-015 filter is an alternative to the 15400-PLM-A01 filter, which is primarily used in Honda vehicles. Both filters are designed to be interchangeable, but they may differ in construction and manufacturer, with the A01 being made by Filtech and the PJ7-015 being a different model.
  • Honda 15400-PJ7-015 (bypass press setting): about 7 psi (51.7 kPa)—noted as acorrected bypass value (kPa typo was reported as 517 kPa, corrected to 51.7 kPa).bobistheoilguy.com
  • Honda 15400-PLM-A01 (bypass press setting): about 9–15 psi (often summarized asroughly 8–11 psi in the same fitment family), though exact spec can vary bysource/filter version. bobistheoilguy.com
Oh no..... I have been using the Hiflo 303 filter https://www.motorcycleproducts.co.u...aces-champion-cof303-x303/1/036432?bike=11227 for a long, long time. I didn't know there was such a thing as a bypass pressure setting :oops: But then again, why would I ? The only thing I care about is that the filter is specified for my bikes. I take one off and put another on..... how do you guys sleep at night having to worry about such things :roflmao::roflmao::roflmao::roflmao::roflmao::roflmao::roflmao:
If your oil filter gets plugged you have a much bigger problem than the oil bypass spring tension. Though the bypass will sometimes open when the engine is cold and the oil does not flow easily through the filter media. Though the automotive Purolator filters have much more filter media than the typical motorcycle filter so it makes it less likely the filter will restrict when the oil is cold. I used the Purolator PBL14610 for years when I had my ST.
