Knee Replacement Infection
Not meaning to tell anyone what to do, just a little FYI. I apologize if that came off wrong.
Didn't come off wrong at all and no apology needed.
I look at the antibiotic/joint discussion a little bit like the 'egg' discussion - one year they are good for you, the next year they are bad for you. ;)
I have to go with what I know that has worked for me over many years.
That's the reason I still ride ST1100s ... :biggrin:
Well I finally got my new knee replacement on Friday 5-15-26. Came home today. I had a little scare Friday night. I ran a temperature for a few hours. Took a Tylenol injection and all was good. Now for the rehab.
Good. My sister is an OR nurse, and she told me after my "total knee" in Jan. 2019, that getting an infection would be just about the worst thing that could happen.
In short, you DO NOT want to get an infection in a replacement joint.
Interesting thread - I'm the one in say 100,000 that had one hip replacement infected over the first 3 months and work out in the long run after the American standard of a plastic temporary replacement with sulfa antibiotics embedded, iv antibiotics then after at least 6 weeks another long term implant. Then the other hip gets done and repeat the 3 step process on that one. Heard from surgeon that dental antibiotics were no longer recommended but he felt play it safe and use them. PITA the day of dental work and aching throughout the body the day after but like Phil I go with the advisement of a seasoned surgeon who saved my ass twice. Feeling lucky to be walking after each of those. Now I can jog but avoid it as regular exercise because of the pounding stress of the joint that goes with running.
My theory of the cause of infection, well it's a theory - something about my ability to dramatically increase blood sugar when I have the trauma of a bone sawed and drilled. I wake up l afterwards feeling a weird giddiness similar to when I used to drink the occasional sugar pop while out on a long ride or at a day long swap meet. Since I've learned to avoid sugar, and eventually even a drink of alcohol. Sleeping better and the hips have been working for 17 and 10 years. Always unhappy to hear someone else is having these same issues. I do know a guy unlucky to get a revision due to a hip recall. Can't say I wish that on anyone either. At least the infected implants just get loose and presumably slide out easily, like that means I was "lucky" in a small way.
No worries, all good. That was 2 years ago, I assume if there was an issue it would have shown up by now.
My infection showed up nine years later. I’m not sure what caused it. But it was a couple of weeks after having my teeth cleaned. From now on I will take antibiotics before having my teeth cleaned.
Had my hip replaced 6 months ago and in the recovery instructions it stated if any dental work is going to be done his office will give me a antibiotic prescription before any work is done. Doctor stated don't mess that up.
Did a little research last night and there are very few research studies on hip/knee replacement infections and the studies out there use very small samples. Patients with certain health conditions like anything have a higher risk.
I hope the reason for the small patient cohorts is that incidents of infection overall are relatively infrequent.
Interesting story - The ortho doc that did both of my shoulder replacements had a knee replacement afterwards.
His replacement got an infection (suspected from not thoroughly sterilized equipment).
He had to go through the same deal as Keith and finally retired as a result.
By the time they finally got rid of the infection his recovery was going to take a really long time.
So I will always err on the side of caution regardless of what the 'prevailing winds' of current medicine may say. ;)
Thank you!
Well the pain is getting much better. Still sore and swollen. Trying to listen to the Dr and Therapist.
You've been through this before for sure.
The good thing is you know what to expect.
And the bad thing is you know what to expect! :biggrin:
Well back to the repair shop. 😩
Yesterday I got a call from my Orthopedic Surgeon. Not what I was expecting. I had surgery # 7 on my knee to put my new knee back in on 5/15/26. During my rehab I thought we pushed it a little too hard. Dr thought I tore the stitches on the inside of my knee. The swelling was bad. And still hurting my knee. It got worse and I called to get back in to see the Dr to see about surgery to replace what I had tore up. He said let’s aspirate the knee just to make sure there is no infection. He did think it was, but let’s make sure. Yesterday he called and told me it is infected again. I I go in this Monday for surgery. Stay in the hospital for a week on heavy antibiotics. Then surgery a week from Monday to take out plumbing and return to normal. Surgeries # 8 and 9 on this knee. Hopefully this takes care of it.
