Not sure, I need to pull them and check. I’m nervous about getting zapped while testing. Been there. Done that. No funSpark at the plugs or are they wet from no fire?
There are some testers for that sort of like a test light for checking regular electricity.Not sure, I need to pull them and check. I’m nervous about getting zapped while testing. Been there. Done that. No fun
I don’t remember disconnecting it.Dropped into the saddle, pulled the clutch, kicked the side stand into place and shifted into gear. Silence ensued, as well as several more attempts to restart the bike.
I haven’t been able to start the bike since the second event. I have a spare switch in the parts bin.That almost sounds like a bad kickstand switch. Does it restart in neutral and die immediately going into gear, every time?
If so, you should be able to temporarily bypass the kickstand switch by jumping the two wires at the connecter together. I would not recommend riding without the sensor though.
Well, if it isn't starting in neutral (when the side switch is bypassed) then I doubt that is the problem, I would not mess with it.I haven’t been able to start the bike since the second event. I have a spare switch in the parts bin.
Tested alreadyWell, if it isn't starting in neutral (when the side switch is bypassed) then I doubt that is the problem, I would not mess with it.
Have you double checked your tip over switch? I always thought they killed the fuel pump, but it might control the coils? Any one know for sure?
