Bike left me stranded :(
That’s the same experience that the rider in South Africa was having. Sometimes it would work and sometimes it wouldn’t and it was difficult to trace the problem when it comes and goes.
That's what a ST1100 failing fuel pump does.
It will be fine for a while then quit.
You remove the cutoff to eliminate it from the mix.
http://www.unclephil.us/West2009Day06.htm
Do you think the fuel pump could be failing at 64k? I've heard of them lasting much longer
In my experience (and I've had a few fail), mileage makes no real difference.
I've had them fail at less than 40,000 miles and past 140,000 miles.
I carry a spare fuel pump setup when I go on long trips - so far I've never had to use it.
I replaced mine with an internal Quantum pump and fuel pressure regulator when they go south.
where do you get the regulator from because I was doing some research and couldn't seem to find them for sale, but I might not have been looking in the right place. I saw the quantum fuel pumps
An external one like this on EBay -
https://www.ebay.com/itm/358857170197
I have talked with Quantum and explained to them that their ST1100 'speced' fuel pump puts out too much pressure.
It fits fine in the stalk but you only need 1.5-2 psi otherwise you will overflow the floats.
The original ST1100 pump has a 'regulator' built in and some guys have 'retroed' it to an aftermarket pump.
https://www.st-owners.com/forums/threads/st1100-fuel-pump-replacement.172602/
well, i tried to start it the next morning and it still didn't start up after sitting overnight. i had actually filled up that afternoon so i was pretty much full on gas.
It can be fitted with an inexpensive aftermarket pump, external or internal with I prefer. Just has to be a low pressure pump.
1786224953165.pngComplements from Uncle Phil :thumb:
