Rear Tire Revolutions Post Bleeding
CT
2005 ST1300 non abs…
Wondering if there should be a very slight drag on the rear wheel after bleeding the whole system. Laying alongside the bike and giving a solid kick gives me about little over 1 1/2 revolutions before the wheel stops turning.
Raising the smc immediately stops rotation and releasing it SEEMS to completely release the pressure, Brand new pads installed so I’m wondering if some is break in, natural level of resistance or if the smc is not fully releasing.
Any helpful advice for troubleshooting or solving this is appreciated in advance. Thanks.
Sounds like you are good to go. I always found a bit of brake drag after I played with the pads and pistons until the bike had been around the block for a mile or two. Once everything was seated properly, I got the 1 1/2 - 2 revs if I gave it a real good kick. With new pads it might take a bit more than a mile or two to properly break (brake(?):biggrin:) them in.
Appreciate it.
I just did braided stainless lines and a vacuum bleed and Wow what a difference. Everything kinda needs to reset itself.
