You think with the lower miles those splines are in need of attention? I think its better than 50/50 its going to need a tire, guessing it may be old, so 100% if I have to pull the wheel, or if you guys think it is a critical service point??? I have some liqui moly goo and some lucas red grease I previously used for the output shaft splines on the BMW's
On the final drive, does it matter if it has the friction modifier? For some reason I think I was directed to use a product without it on the BMW???
I have some OAT coolant, its "Ford" specific, any objection to that? The NGK's 9's coming, M1-110A is at walmart, think the rest of the fluids I can get at Walmart
Question, I think I am seeing that production of the civilian bike ended in 2012 and when I do parts searches for a 2016 I dont get accurate results?? I cant land on an air cleaner... Are the PA's the same as the 12 model civilian? And only PA's were produced 13-16?
Thanks again for all the help
