Picked up a used 40 amp the other day, came with all new O-rings in packages, alternator, Base and mounting plate are assembled. I would like to insure it is functional before I tear down bike.
Observations: When I hold mounting plate on base and spin gear assy. there is visually runout showing. When I support both mounting plate and end bearing by nut and have somebody spin gear assy., it spins true. I can not feel a bad bearing, it just seems a little loose. When I attach the alternator to the base, things also seem to tighten up and run true. Alternator is clean but has a little road grim inside on wound coils. I noticed when I turn alternator shaft clockwise looking down on shaft, everything is smooth and quiet. When I turn counterclockwise I get a very small scratch sound from inside unit. Does anybody know which way a 40 amp rotates? The plan is to remove the 28 amp and base and install (new/used) 40 amp and base. Bases should be the same except for mounting plate, at least by all the research I have gathered thru this forum and honda manuals. I am upgrading a Black "91" with 65,000 miles on it.
