Need photo of cam lobes from TDC
I agree with Doug; pictures are not necessary. As I posted before, the appearance of the cam ends at TDC are as Doug described and are clearly depicted in this schematic Martin posted in your other thread [if not, pull the belt and cams and install correctly]:the service manual pictures that have been posted multiple times show the same information as a picture would show.
The index lines are clearly identifiable as "lines" and the punch marks are clearly identifiable as "dots", cut into the ends of the cams.
With the crank at TDC #1 the index lines will be pointing outward on the right side cylinders, like in the diagram, and the punch marks will be pointing outward on the left side cylinders, like in the diagram.
