Terminator2
there is a voltage drop across anything carrying current, and even more drop if there's corrosion in the path somewhere. So, depending on where you're measuring voltage as you move away from the battery you're going to get a different result.
What's the voltage with the bike running at the battery terminals? If you're over 14 there then all these other readings don't really mean much, and as has been mentioned before it could be the battery itself even though its not very old.
Installed new battery. No change until I disconnect right side instrument panel connector. Then reading is 0.06 mA.
Three circuits are affected. Trying to figure out location of power breach.
