The battery I purchased in March already failed the test half way through the summer, unfortunately my ST was my only transportation, so I couldn't afford the down time while I sent the battery back. Fast forward to last week. My bike had been sitting about a week since the last time it was run- which was for about 45 minutes when I let it warm up and moved it around the yard. I tried cranking it- very slow, turned over about 3 times and stopped. Boosted it, let it warm up and run idling for about 45 minutes, then rode to town and back- about 20 miles round trip. I put the battery tender on it then and left it charging the rest of the day. Went back out around 10:30 and the bike was no better than in the morning- just a half-hearted crank and that was it. I pulled the battery, brought it in the house and tested it- 12.9 volts. Hmmmm. Put the Battery Tender on it and within a minute it went to full green light- "Charged". I left it on for 3 days anyway.
I just put the battery in the ST to test it again. Turned key on for about 20 seconds, then off. Tested battery with key off: 12.8 volts. Turned key on- 11 volts. Voltage while cranking- 9.8 volts. Keep in mind this was right after 3 days on the Tender. It did at least take a charge- the bike cranked and started. I plan to ride the bike a couple times this week, I'll see how it performs then.
I did e-mail Scorpion a couple days ago with the symptoms and asking their procedure to test the battery before sending it back- I want to follow their approved procedure- but didn't hear back Thursday or Friday. Hopefully this week.
