Inquiring minds wanna know...how has the Odyssey PC545 held up for you?
In one of my follow-up posts in the installation article, I said I'd be happy if the Odyssey lasted 3 years. Well, I'm happy because 3 years passed in October of 2012, and any additional service I get from it I view as bonus time.
I added a Battery Bug (BB) monitor a month ago, and it (of course) said 100% life remaining as soon as it was connected ... it had no recorded history to think otherwise. The BB readings since then have been as follows:
57% & 13.0v on 1/2/13 after initial engine start
50% & 12.8v on 1/5/13 after several starts on a 45? day
49% & 12.6v on 1/15/13
46% & 12.9v on 1/21/13 after several starts during a 50? ride to Richmond, VA (about 160 miles total)
43% & 13.0v on 2/3/13
28% & 13.1v on 2/4/13 after starting when the bike sat out in 32? to 45? temps all day at work
28% & 12.7 on 2/6/13 aftter starting when leaving work today, 50? high temp
The 28% values have me a little concerned, but the battery starts the engine as it always had when in cold temperatures. The voltage numbers are good, but I haven't tried checking the voltage while cranking. I'm waiting to see if I get the "ST1300 telltale sign" that the battery is nearing its death ... when the clock/tripometer displays zero out after a start.
OTOH the Odyssey is not high on CCA, but it's supposedly very good on continuously cranking an engine. Other than the one time I ran it down when I left my headlights on, this battery has been flawless. The only thing I disliked when I ordered the Odyssey at a local Batteries Plus store was that they "quick-charged" it just prior to me coming to pick it up. Next time I'll know to ask them not to charge it at all, and I'll do an initial slow charge using my Battery Tender.
I do not use the Battery Tender on a regular basis ... only use it after I've farkled around with the ignition on for several minutes. I fully intend to post an update when this one finally calls it quits, but I won't hesitate to get another.
EDIT: Here are some PC545 spec's from the Odyssey website ...
545 cranking amps for 5 seconds
495 cranking amps for 10 seconds
420 cranking amps for 20 seconds
Short circuit current over 1200A
14Ah
18 minute reserve capacity with 25amp load
CCA - 185
