STRider
I'd love members with more experience with fail modes in these systems to chime in, but... You mention that the clutch and brakes work correctly. If the obstruction I suggested was in the port of the bleed screw, then no, it shouldn't prevent it from operating 'normally'. With air removed and the system full of fluid between the master cylinder at the bar, and the slave cylinder in the clutch, or the pistons of the brakes, they should work. But my hypothetical obstruction would only prevent the exit of fluid via the bleeder when it was opened to do so.Ok, well I took it for a spin and all feels good. If it were clogged I am guessing it would be hard to stop or it would
be noticeably worse? Also the clutch would feel mushy/different?
What was the condition of the fluids that you displaced from the clutch slave cylinder or the brake calipers? You called it 'dirty'. Was it just discolored? Was is cloudy or emulsified? (think milky in appearance) Was there any floating debris in it?
