Yeah, absolutely. To do embedded data like a MAC address right, during electrical test of the devices they will also write data to otherwise blank writeable memory space in the chip. It's far easier to simply encode a character string (MAC address) into the design to make fabricating the device and its test suite much less expensive.I have heard of Chinese electronics coming from the factory as clones; they all have the same MAC address.
Thinking some more this would not be sufficient, each dongle will need to be paired to the 20s so the dongle "knows" what to send audio to. Maybe you could pair one, clear the 20s pair the second dongle, clear the 20s pair the third dongle, clear the 20s and pair the 4th. Now all the dongles are paired with the 20s and the 20s is paired with the 4th dongle. Then, if they are clones, hopefully all 4 dongles would look the same as #4 to the 20s.I have heard of Chinese electronics coming from the factory as clones; they all have the same MAC address. Have you tried to get one of the other dongles to connect without pairing? That would be lucky if this was a case of cheep cloned MAC's. It won't pair the second because it is already paired, it has the same MAC.
I already have 4 Senas. But then I have to swap Senas on the helmet ...Just buy 4 Senas and pair 1 to each BT device!
Tony - Since I paired the second dongle to the Sena after a factory reset, I have not tried to connect to the original dongle.Thinking some more this would not be sufficient, each dongle will need to be paired to the 20s so the dongle "knows" what to send audio to. Maybe you could pair one, clear the 20s pair the second dongle, clear the 20s pair the third dongle, clear the 20s and pair the 4th. Now all the dongles are paired with the 20s and the 20s is paired with the 4th dongle. Then, if they are clones, hopefully all 4 dongles would look the same as #4 to the 20s.
Better the garage than the wood shed.Sounds like a trip out to the garage just to see ....
Didn't work - evidently the dongles do have unique MAC addresses after all.Tony - Since I paired the second dongle to the Sena after a factory reset, I have not tried to connect to the original dongle.
