cheap moly paste
ireland
honda st1100
Here is link for anyone looking for Final drive / Rear wheel Molly paste found it very difficult to get in Ireland so ordered of AliExpress much, much cheaper also, just sharing link am not making anything from any sale ,
Molykote G-n plus paste on AliExpress.com
it not a working link just go to AliExpress & you find the paste type it in
Molykote G-N Plus has 6-10% Moly content. Just FYI.
I use it all the time at work, it's a great assembly lube and I use it for leveling bolts on heavy machinery. Works a little better than anti sieze. I do not use it on my rear wheel spines.
Molycote G-n + is moly grease, not paste. As noted, its moly content is insufficient for the splines. This stuff is good for the driveshaft.
It is considered a paste by Dupont (it's very thick), but the Moly content is not high enough for our uses. There are other solid lubricants in it as well.
You can look up the SDS for it to verify that, it lists the composition. I believe 50-60% moly is what we're looking for with rear wheel spline lube.
sorry , spent good while researching several weeks back was pretty sure it had least 60% moly content at time just as well I made the post as it saved my new to me final drive! Any ideas what can get local in Ireland from a hardware or boat / machinery supplier please
Loctite 8012 is what most folks get these days. It's pretty available online, no idea about locally in IE. There aren't a ton of applications requiring that much moly, so it's not too available at most places, definitely a niche product.
Dow Corning’s g-n paste is specified in the original workshop manual. The requirement was for 40% MoS2 - although some of the recommended products have less than that. But we never found out whether the 40% was by weight or by volume. With MoS2 it makes a big difference MoS2 has a density of about 5gm / cm3 - so 5 times denser than water. About the same density as iron pyrite - fools gold.
There was confusion because the Honda Product was called Moly 60. They stopped supplying it - I believe it was G-n Paste from Dow Corning, who stopped making it for a while. I contacted Dow Corning at the time about it, but they warned me off Silicone based products - they are generally not suitable for extreme pressure situations.
The fact that Honda had got Poly-si - a company that specialises in using silicone bases - to recreate the MolyPaste - seemed to lead to a situation where Honda had no replacement for Moly 60 / g-n Paste and were oddly silent about the issue.
Whether the Ali Express stuff is the same is anybody’s guess. Dow Corning moved over to Silicone based lubricants a while back. The trademark now belongs to DuPont.
The company selling it through Ali Express is Chinese company trading using the word ‘Molykote’ in its name. ‘Molykote Special Lubricati…..”. Ali Express has customer feedback figures which would give me cause for concern. Operating since 2023.
If it is cheap, I would be very wary of it. My opinion only.
You can always find out. Contact DuPont and ask if this is a legitimate outlet for the genuine Molykote Brand.
My take is that you can only make moly grease/paste cheap if you cut down on the Moly.
We know that the loctite stuff does a good job, and we know that Rocol’s version is also good.
This link in Uk
https://www.st1300-accessories.co.uk/miscellaneous
has some Rocol Paste - 4 lots left. He bought a big batch and is selling it in 100g containers. Ie you don’t get the big tin ! £40 - which is a lot, but that’s how much it costs. The 100g of paste will last you longer than the bike.
50% Moly , and the same as the one specified in the Honda manual - except Rocol changed the name to Dry Moly Paste. I have confirmation of that from Rocol.
Bike-Quip are not fulfilling orders for a couple of weeks after 17 August - he’s a one man business and is on hols, I guess. I use the Rocol stuff, and it’s every bit as good as the g-n paste that Honda use to supply.
You might find somewhere online that has the loctite.
When in doubt, always refer to the Honda service manual, ..... er, eh, nevermind.
edit: I see John Heath already mentioned it while I was looking it up.
He who hesitates, is upstaged by John
just to be clear, the "er, eh, nevermind" wasn't in reference to John, it was a reference to the fact that the 1100 factory manual clearly calls out Molycote G-n as acceptable for the 40%+ moly requirement applications.
